Hello,
I'm building a basic IOC under windows by doing the following:
makeBaseApp.pl -t ioc <name>
makeBaseApp.pl -i -t ioc <name>
Then I build the ioc, and run it without databases. Upon exit I get the following errors
CAS: Client accept error was "WINSOCK Error 10004"
CAS: UDP recv error (errno=WINSOCK Error 10004)
..\online_notify.c: CA beacon routing (connect to "10.123.255.255:5065") error w
as "WINSOCK Error 10093"
or
CA cast server: Unable to fetch N characters pending
Has anybody had this error, and know how to fix ?
Thanks heaps,
Mark Clift.
This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
