1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: back propagating error states (accidentally)
To: [email protected]
Date: Wed, 22 Apr 2009 23:35:59 +0200
On Mittwoch, 22. April 2009, Leicester, PJ (Pete) wrote:
> What I need to do is propagate this error state back to the
> mbbo records so that it is visible on the edm screen.
It is funny that you ask this because just today I had the "inverse"
problem: I had a record that for no obvious (to me!) reason went into
LINK/INVALID state. I checked and re-checked again all the input links and
all links pointing to my record and found nothing INVALID and no broken
links.
I found the solution to this riddle when I noticed that the record has an
output link with PP option and that my first record does /not/ become
LINK/INVALID if the second one (an ao record) gets disabled. Now the second
record's OUT link is indeed broken and this seems to result in its
processing returning an error so that dbPutLink (from the first record)
thinks that it has failed when in fact the value gets transported just
fine, only the processing of the target record fails. Whereas if the second
record is disabled, processing is successfully "not done" so the dbPutLink
in the first record succeeds ;-)
This is probably well known, maybe even documented, and (arguably) correct
behaviour. Yet it's a pitfall that took me some time to figure out.
Cheers
Ben
back propagating error states Leicester, PJ (Pete)
Prev: XIA xMAP software Mark Rivers
Next: Hy8401: "PROM:INVALID PROM HEADER" 汪启胜
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: back propagating error states Allison, Stephanie
Next: XIA xMAP software Mark Rivers
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
