1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: back propagating error states
To: "Leicester, PJ (Pete)" <[email protected]>, "Andrew Johnson" <[email protected]>, <[email protected]>
Date: Wed, 22 Apr 2009 11:23:36 -0700
Hi Pete,
I think you are right - the put callback may complete before the record is processed the 2nd time due to the severity change.   And vice-versa - once the communication is good again, you will have a bad severity on that mbbo until it is processed the 2nd time when the downstream record goes good again.
Stephanie
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Leicester, PJ (Pete)
> Sent: Wednesday, April 22, 2009 10:15 AM
> To: Andrew Johnson; [email protected]
> Thanks Andrew and Stephanie. The addition of the CP flag does work as
> far as I can see. It certainly seems ok from edm.
> My one concern now is if I have a client using put callback to change
> the mbbo record will it see the error state in the mbbo record or is the
> callback complete before the SDIS MS CP updates the mbbi's error status.
> Perhaps there is a race condition here?
> Pete
> From: Andrew Johnson [mailto:[email protected]]
> Sent: 22 April 2009 16:29
> To: [email protected]
> Cc: Leicester, PJ (Pete)
> Subject: Re: back propagating error states
> Hi Pete,
> On Wednesday 22 April 2009 09:27:57 Leicester, PJ (Pete) wrote:
> > I tried linking the SDIS from the mbbo to the longout record with
> > maximise severity set. This did make the mbbo reflect the longout's
> > error state but only after being processed a second time so is far
> > from ideal.
> If you were to add a CP flag to that SDIS link it would cause the mbbo
> record
> to get processed whenever the field it was pointing to changed.  I would
> suggest pointing it to the SEVR field of the longout record, but make
> sure
> that you also set the mbbo.DISV field to something outside the range
> 0..3.
> I'm not 100% sure this will work, but I think it should.
> - Andrew
> The best FOSS code is written to be read by other humans -- Harold Welte
> This e-mail and any attachments may contain confidential, copyright and or privileged
> material, and are for the use of the intended addressee only. If you are not the intended
> addressee or an authorised recipient of the addressee please notify us of receipt by returning
> the e-mail and do not use, copy, retain, distribute or disclose the information in or attached
> to the e-mail.
> Any opinions expressed within this e-mail are those of the individual and not necessarily of
> Diamond Light Source Ltd.
> Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments are free
> from viruses and we cannot accept liability for any damage which you may sustain as a
> result of software viruses which may be transmitted in or with the message.
> Diamond Light Source Limited (company no. 4375679). Registered in England and Wales
> with its registered office at Diamond House, Harwell Science and Innovation Campus,
> Didcot, Oxfordshire, OX11 0DE, United Kingdom
Re: back propagating error states Andrew Johnson
RE: back propagating error states Leicester, PJ (Pete)
Prev: RE: back propagating error states Leicester, PJ (Pete)
Next: Re: back propagating error states Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
