1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: back propagating error states
To: [email protected]
Date: Wed, 22 Apr 2009 10:29:02 -0500
Hi Pete,
On Wednesday 22 April 2009 09:27:57 Leicester, PJ (Pete) wrote:
> I tried linking the SDIS from the mbbo to the longout record with
> maximise severity set. This did make the mbbo reflect the longout's
> error state but only after being processed a second time so is far from
> ideal.
If you were to add a CP flag to that SDIS link it would cause the mbbo record
to get processed whenever the field it was pointing to changed.  I would
suggest pointing it to the SEVR field of the longout record, but make sure
that you also set the mbbo.DISV field to something outside the range 0..3.
I'm not 100% sure this will work, but I think it should.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
RE: back propagating error states Leicester, PJ (Pete)
Prev: Re: Priorities of epicsThreads on Linux Andrew Johnson
Next: RE: back propagating error states Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: back propagating error states Leicester, PJ (Pete)
Next: RE: back propagating error states Leicester, PJ (Pete)
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
