When I compile motor 6-4-2 under win32-x86 with vs2008 (cl version
14.00.50727.762), it reports the following errors:
make[1]: Entering directory
`/c/epics/synApps_5_4/support/motor/6-4-2/motorApp/MotorSrc/O.win32-x86'
Installing generic include file ../../../include/motor.h
cl /nologo /EHsc /GR -c /D_CRT_SECURE_NO_DEPRECATE
/D_CRT_NONSTDC_NO_DEPRECATE /D__STDC__=0 /Ox /GL /W3 /w44355
/MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..
-I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include
-Ic:\\epics\\synApps_5_4\\support\\asyn\\4-10\\include
-Ic:\\epics\\synApps_5_4\\support\\seq\\2-0-12\\include
-Ic:\\epics\\base-3.14.10\\include\\os\\WIN32
-Ic:\\epics\\synApps_5_4\\support\\motor\\6-4-2\\include /Tp
..\\motorRecord.cc
motorRecord.cc
c:\epics\synapps_5_4\support\motor\6-4-2\motorapp\motorsrc\motor.h(126)
: error C2014: preprocessor command must start as first nonwhite space
: fatal error C1017: invalid integer constant expression
make[1]: *** [motorRecord.obj] Error 2
make[1]: Leaving directory
make: *** [install.win32-x86] Error 2
In motor.h(126): #if defined(_WIN32) || #cpu(i386) || defined (_M_IX86)
|| defined (_X86_),
the #cpu(i386) assertion confuses compiler. If I split it over two lines
then it works.
#if defined(_WIN32) || defined (_M_IX86) || defined (_X86_)
#define LSB_First (TRUE) /* LSB is packed first. */
#elif #cpu(i386)
It seems MSVC does not accept directives mixed.
Dr. Xiaoqiang Wang
Paul Scherrer Institut, WBGB/010
5232 Villigen PSI, Switzerland
- Re: Motor record compilation error under win32-x86 Ron Sluiter
Re: Genesys Power Suppy LAN driver Burkhard Kolb
RE: Problems using the sscan record Mark Rivers
<2009>
答复: Problems using the sscan record 张招红
<2009>
