> Now, I want to save the ADC.VAL,
DAC.VAL and mca.VAL at the same time. But I can't get it.
> I find the data of ADC is later than
the data of mca evenif I set scan1.DDLY as 0. So please tell me how to
gain the float data and the array data at the same time.
How much later is the ADC than the MCA? What
times are you looking at to determine this?
> I find the value of RnROI field are
different from the value of specture in the saved file.
> That means scan1.DnnPV and
scanH.DnnPV be saved in the different time even if I set scan1.DDLY as 0
second.
> So would you mind tell me how to set
the value of scanH.DDLY, scan1.PDLY, scan1.DDLY and scan2.PDLY?
> I don't know wheater they
should gain in the same time or not.
I don’t understand how the RnROI field
could be different from that of the spectra. The RnROI field is computed when
the MCA stops acquiring, which is also when the sscan record reads both the
spectra and the ROIs.
What is the evidence that the ROIs are
incorrect?
I set up a 2-D scan as follows:
scan1 record: Drive is X motor VAL field,
trigger is scanH.EXSC field. I set its detectors to be ADC.VAL, DAC.VAL and so
on.
scanH record: No positions. Detector
trigger is the field for starting MCA. The detector is mca.VAL which is
the array .
Now, I want to save the ADC.VAL, DAC.VAL
and mca.VAL at the same time. But I can't get it. I find the data of ADC is
later than the data of mca evenif I set scan1.DDLY as 0. So please tell
me how to gain the float data and the array data at the same time.
Yan Fen
Shanghai Synchrotron Radiation Facility
Shanghai Institute of Applied Physics
Chinese Academy of Sciences
Zhangheng Rd
239,Pudong Dist.,
Shanghai 201204
China
Tel:+86-21-33933191
