1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: longout record issue
To: Emmanuel Mayssat <[email protected]>
Cc: epics <[email protected]>
Date: Tue, 07 Apr 2009 09:32:15 +0200
Hi Emmanuel,
That looks like the problem I have reported in 2007 (and which is still "open" in Mantis):
Summary  	 gcc 3.2.3 bug: long integer values are corruped in R3.14.9
Description When writing integer values with a CA client (e.g. medm) to a long integer channel (e.g. longout record), the upper bytes get corrupted. The lower 2 bytes are OK.
I can't see the error when the client is caput from base.
Client and IOC run on a linux-x86 machine.
The problem is new in 3.14.9.
See http://www.aps.anl.gov/epics/mantis/view_bug_page.php?f_id=0000291
It happens when using g++ 3.2.3 with option -O3.
Dirk
Emmanuel Mayssat wrote:
Hello all,
I have noticed oddities with my longout records.
Particularly when I use the soft Channel record.
record(longout, "myLO") {
	field(VAL ,"100")
	field(SCAN, "Passive")
	field(DTYP, "Soft Channel")
Now if I create a medm text entry attached to this PV, and attempt to
modify the PV, it updates but not as expected. For example, if I enter
the value 10, the PV is updated to -11100023 (or something like that)
I am using medm 3.1.1 compiled against EPICS 3.14.9.
I have other longout records which are not "Soft Channel".
They correctly update with the same medm widget.
Any idea?
Emmanuel
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
longout record issue Emmanuel Mayssat
Prev: RE: longout record issue Mark Rivers
Next: problem when running Channel Archiver zhangdemin99
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: longout record issue Andrew Johnson
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
