Several changes have been made to the ASYN support module at this
week's EPICS codeathon. Here's your chance to comment on them before
they become part of the next release.
1. asynReport at detail level 0 now reports only disconnected
subaddresses. The previous level 0 report was far too long for
register-based devices that sometimes had scores (or even hundreds) of
addresses in completely benign states.
2. The autoconnect code has undergone considerable modification. When
a port is registered with autoConnect true, or whenever a port
disconnect exception is raised on an autoConnect port, an attempt at
connection occurs immediately followed by retry attempts at 20 second
intervals. Attempts to queue requests to a disconnected port (even an
autoConnect port) will be rejected. These changes have been made to
reduce the occurences of 'connection flurries' and to ensure that
requests do not languish in the queue when connections are broken.
3. Setting the trace mask or trace I/O mask for a port now also sets
the trace mask or trace I/O mask for every device associated with that
port.
4. Passing a NULL pasynUser argument to the setTraceMask and
setTraceIOMask will set the asynBase (default) trace mask or trace I/O
mask. Previously there was no mechanism for changing the default
trace masks.
5. Add new asynStatus codes, asynDisconnected and asynDisabled.
Attempts to queue a request to a disconnected or disabled port return
these codes, respectively. Future changes to record support may
propogate these to the record alarm status field.
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
ai record with dtyp of "raw soft channel" Patrick Thomas
Re: Asyn changes Eric Norum
<2009>
Re: ai record with dtyp of "raw soft channel" Ralph Lange
<2009>
ANJ, 31 Jan 2014 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
