Mark, Lewis,
This idea is to have several substitution files for maintenance purpose
instead of a huge one. But now, I realize that I could generate that
master_substitution_file when I run 'make' in my msi template
directory...
Thank you ...
Note: I was hoping that the include directive would work. It apparently
doesn't.
Emmanuel
On Thu, 2009-04-02 at 17:47 -0400, J. Lewis Muir wrote:
> On 4/2/09 5:23 PM, Emmanuel Mayssat wrote:
> > Hello all,
> > I have several substitution files, which I could load with a series of
> > dbLoadTemplate. Is there a way to have only one dbLoadTemplate hand have
> > a substitution file such as follow:
> > cat master_substitution_file<<EOT
> > include substitution_file_1
> > include substitution_file_2
> > include substitution_file_3
> > EOT
> > and in stcmd
> > dbLoadTemplate("$PATH/master_substitution_file")
> > Well, this doesn't seem to work.
> > is there a way to include dbTemplate/substitution together?
> Hi, Emmanuel.
> You can concatenate a bunch of substitutions files into one big
> substitutions file using the UNIX cat command and shell redirection. Is
> this what you're wanting or are you wanting to do this at run-time?
> For example:
> $ ls -1
> ipUnidig.substitutions
> motor.substitutions
> scanParms.substitutions
> $ cat *.substitutions > all.substitutions
> Move all.substitutions to the desired location (typically the same
> directory as st.cmd).
> Then in st.cmd:
> dbLoadTemplate("all.substitutions")
> Lewis
- dbLoadTemplate and includes Emmanuel Mayssat
- Re: dbLoadTemplate and includes J. Lewis Muir
ai record with dtyp of "raw soft channel" Patrick Thomas
<2009>
<2009>
