1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: JCA2 vs CAJ
To: GaryCarr <[email protected]>, [email protected]
Date: Tue, 24 Mar 2009 15:01:43 -0400
On 3/24/09 14:43 , "GaryCarr" <[email protected]> wrote:
> Are there any limitations that apply to one, and not the other?
Other differences:
When you close a JNI JCA channel, that's it.
CAJ will send a final value update to indicate that
the channel is now invalid, in case you registered monitors.
When you create duplicate channels like this
   final Channel ch1 = jca_context.createChannel("fred", conn_callback);
   final Channel ch2 = jca_context.createChannel("fred", conn_callback);
JNI JCA will give you 2 different ones,
while CAJ, within the same context, you will return
the same, i.e. ch2 == ch1.
If you then later clean up like this
  ch2.destroy();
  ch1.destroy();
you get a problem in CAJ because ch2.destroy actually
destroys both.
==> To be compatible, you do your own reference counting,
keep a hash of used channel names.
-Kay
JCA2 vs CAJ GaryCarr
Prev: Re: JCA2 vs CAJ Kasemir, Kay
Next: Fonts for Probe under Scientific Linux Schoeneburg, Bernd
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: JCA2 vs CAJ Matej Sekoranja
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
