1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: JCA2 vs CAJ
To: GaryCarr <[email protected]>, [email protected]
Date: Tue, 24 Mar 2009 14:54:28 -0400
On 3/24/09 14:43 , "GaryCarr" <[email protected]> wrote:
> Are there any limitations that apply to one, and not the other?
In case you depend on the exact verbiage of error messages,
they differ. CAJ tends to give more specific ones like
access permission error while JCA might just report write error.
CAJ seems to be perfectly fine with multithreaded access,
while I've run into deadlocks when for example calling JNI JCA
from one thread, trying to remove a monitor, while a JNI JCA
value update arrived on another thread for another PV.
I think Jeff said that the CA client library itself does not
lock in those cases, to the lock might be inside the JNI code,
but in any case you must not lock anything in your code
when dealing with JNI JCA because that can result in deadlocks.
-Kay
JCA2 vs CAJ GaryCarr
Prev: JCA2 vs CAJ GaryCarr
Next: Re: JCA2 vs CAJ Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
