1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: JCA2 vs CAJ?
To: GaryCarr <[email protected]>
Cc: [email protected]
Date: Tue, 24 Mar 2009 13:21:49 -0400
At SNS we use JCA/JNI for production and use JCA/CAJ for testing through the gateway outside the controls network. JCA/CAJ is more convenient for external use since it doesn't require the EPICS libraries and JNI plugin to be present on the client machine. However, we encountered serious issues with earlier versions of CAJ, so it isn't accepted for use inside of our controls network. In particular, there was an issue with IOC crashes being correlated with CAJ clients. That may have since been fixed. Another issue which may have also been fixed is that channels would sometimes fail to reconnect automatically. We also encountered connection issues when attempting to connect thousands of channels using CAJ.
Basically, JCA/JNI tends to be more acceptable for production since it uses the native CA libraries that are supported in the EPICS community. JCA/CAJ is a very good, convenient, pure Java attempt at implementing the same CA client protocol, but since it isn't the "official" CA implementation it isn't as well accepted. More testing will be needed to provide confidence in JCA/CAJ for use inside the controls network.
best regards,
tom
On Mar 24, 2009, at 12:19 PM, GaryCarr wrote:
Here at LANL/AOT-IC we are just starting to replace JCA1 with JCA2 in our Java applications. Since moving between JCA2 and CAJ is just a one line code change, I have run my applications with both, and don't see any real differences between the two. A couple of questions.
How many people are using JCA2?
how many people are using CAJ?
Is there any reason to choose one over the other?
JCA2 vs CAJ? GaryCarr
Prev: JCA2 vs CAJ? GaryCarr
Next: Re: JCA2 vs CAJ? J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
