1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: environ symbol on MacOS X with EPICS base 3.14.10
To: [email protected], [email protected]
Date: Mon, 23 Mar 2009 15:40:43 -0500
OK.  Thanks for the information.
Bill Lavender
On Mon, Mar 23, 2009 at 03:38:36PM -0500, Eric Norum wrote:
> This change is in the CVS repository for the R3.14 branch and the CVS
> head.
> On Mar 23, 2009, at 3:05 PM, Bill Lavender wrote:
>> I have encountered a minor problem with EPICS base 3.14.10 on MacOS X
>> systems that I would like to report.  In my situation, I have a Python
>> module coded in C that invokes a library of mine, which in turn links
>> to the EPICS libCom and libca libraries.  The symptom of the problem
>> is
>> that when I try to import the Python module, I get an error like this:
>> ImportError: dlopen(./MpPrivate.so, 2): Symbol not found: _environ
>>  Referenced from: /opt/epics/base-3.14.10/lib/darwin-x86/libCom.
>> 3.14.10.dylib
>>  Expected in: flat namespace
>> This is on a computer running MacOS X 10.5 (Leopard).
>> The source of the problem is that MacOS X defines the symbol 'environ'
>> in some situations, but not all situations.  I have found a variety of
>> forum posts and mailing list entries on the Internet that describe the
>> problem and how to fix it.  The message
>>  http://lists.apple.com/archives/xcode-users/2004/jan/msg00230.html
>> gives a particularly clear description of the issue and I quote part
>> of
>> it here:
>>> _environ is defined in /usr/lib/crt1.o, which is only linked into
>>> executables. The corresponding file for dylibs (which frameworks
>>> use) is
>>> /usr/lib/dylib1.o and doesn't define _environ. Annoying as that is,
>>> it's
>>> correct because otherwise your library's _environ would be different
>>> from
>>> the _environ of the executable that loaded it.
>>> If you want to use _environ in a library on Mac OS X, you should use
>>> *_NSGetEnviron() instead. It's defined in /usr/include/crt_externs.h.
>>> Hope this helps,
>>> Eric
>> As far as I can tell, the only place in EPICS base that uses the
>> 'environ'
>> symbol is the function epicsEnvShow() in "src/libCom/osi/os/default/
>> osdEnv.c"
>> I have created a modified version of this function that looks like
>> this
>>  #if defined(__APPLE__)
>>  #  include <crt_externs.h>
>>  #  define environ (*_NSGetEnviron())
>>  #endif
>>   * Show the value of the specified, or all, environment variables
>>  epicsShareFunc void epicsShareAPI epicsEnvShow (const char *name)
>>      if (name == NULL) {
>>  #if !defined(__APPLE__)
>>          extern char **environ;
>>  #endif
>>          char **sp;
>>          for (sp = environ ; (sp != NULL) && (*sp != NULL) ; sp++)
>>              printf ("%s\n", *sp);
>>      else {
>>          const char *cp = getenv (name);
>>          if (cp == NULL)
>>              printf ("%s is not an environment variable.\n", name);
>>          else
>>              printf ("%s=%s\n", name, cp);
>> I haven't actually tested the modified version of the function, since I
>> do not use epicsEnvShow() for anything, but this change is enough to
>> get
>> my Python module to load successfully without any missing symbols.
>> Hope this helps,
>> Bill Lavender
> Eric Norum <[email protected]>
> Advanced Photon Source
> Argonne National Laboratory
> (630) 252-4793
environ symbol on MacOS X with EPICS base 3.14.10 Bill Lavender
Re: environ symbol on MacOS X with EPICS base 3.14.10 Eric Norum
Prev: Re: environ symbol on MacOS X with EPICS base 3.14.10 Eric Norum
Next: RE: Motor problems(RBV can't update itself) Xu, Huijuan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: JCA2 vs CAJ? GaryCarr
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
