1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: environ symbol on MacOS X with EPICS base 3.14.10
To: [email protected]
Cc: [email protected]
Date: Mon, 23 Mar 2009 15:38:36 -0500
This change is in the CVS repository for the R3.14 branch and the CVS head.
On Mar 23, 2009, at 3:05 PM, Bill Lavender wrote:
I have encountered a minor problem with EPICS base 3.14.10 on MacOS X
systems that I would like to report.  In my situation, I have a Python
module coded in C that invokes a library of mine, which in turn links
to the EPICS libCom and libca libraries. The symptom of the problem is
that when I try to import the Python module, I get an error like this:
ImportError: dlopen(./MpPrivate.so, 2): Symbol not found: _environ
Referenced from: /opt/epics/base-3.14.10/lib/darwin-x86/libCom. 3.14.10.dylib
 Expected in: flat namespace
This is on a computer running MacOS X 10.5 (Leopard).
The source of the problem is that MacOS X defines the symbol 'environ'
in some situations, but not all situations.  I have found a variety of
forum posts and mailing list entries on the Internet that describe the
problem and how to fix it.  The message
 http://lists.apple.com/archives/xcode-users/2004/jan/msg00230.html
gives a particularly clear description of the issue and I quote part of
it here:
_environ is defined in /usr/lib/crt1.o, which is only linked into
executables. The corresponding file for dylibs (which frameworks use) is /usr/lib/dylib1.o and doesn't define _environ. Annoying as that is, it's correct because otherwise your library's _environ would be different from
the _environ of the executable that loaded it.
If you want to use _environ in a library on Mac OS X, you should use
*_NSGetEnviron() instead. It's defined in /usr/include/crt_externs.h.
Hope this helps,
Eric
As far as I can tell, the only place in EPICS base that uses the 'environ' symbol is the function epicsEnvShow() in "src/libCom/osi/os/default/ osdEnv.c" I have created a modified version of this function that looks like this
 #if defined(__APPLE__)
 #  include <crt_externs.h>
 #  define environ (*_NSGetEnviron())
 #endif
  * Show the value of the specified, or all, environment variables
 epicsShareFunc void epicsShareAPI epicsEnvShow (const char *name)
     if (name == NULL) {
 #if !defined(__APPLE__)
         extern char **environ;
 #endif
         char **sp;
         for (sp = environ ; (sp != NULL) && (*sp != NULL) ; sp++)
             printf ("%s\n", *sp);
     else {
         const char *cp = getenv (name);
         if (cp == NULL)
             printf ("%s is not an environment variable.\n", name);
         else
             printf ("%s=%s\n", name, cp);
I haven't actually tested the modified version of the function, since I do not use epicsEnvShow() for anything, but this change is enough to get
my Python module to load successfully without any missing symbols.
Hope this helps,
Bill Lavender
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
Re: environ symbol on MacOS X with EPICS base 3.14.10 Bill Lavender
Prev: Re: Motor problems(RBV can't update itself) Ron Sluiter
Next: Re: environ symbol on MacOS X with EPICS base 3.14.10 Bill Lavender
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: environ symbol on MacOS X with EPICS base 3.14.10 Bill Lavender
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
