Dear Tech-talk,
I finally have the time to ask this question. When trying to set the
default mask via the config file I haven't had any luck when applying
it to a group, i.e.
GROUP NULL HV ---T-
GROUP HV Boards
However, it works as expected for an individual channel
CHANNEL West_1 TOF:HV:Positive:West:1:14:1:vmon ---T-
Reading through the manual, in version 1.2.23 in Ch. 6 it says under
the "Group or Channel" that the mask is only applicable to CHANNEL.
However when discussing the sample config file it says:
In this example the default mask "-----" is used for every channel.
That is, no masks are specified on the group and channel lines.
Which seems to indicate one can set a mask via the group.
Is there a syntax difference between setting the mask for GROUP and
CHANNEL?
It would make it considerably easier for me if I could set it in the
group else I would need to do it for all 571 channels (could be worse
I know).
I am using ALH 1.2.24 on OS X 10.5.6 PPC with EPICS 3.14.9
Bertrand
Re: epics GUIs (update) Elder Matias
Re: Motor problems(RBV can't update itself) Ron Sluiter
<2009>
RE: Motor problems(RBV can't update itself) Xu, Huijuan
24 bit ADC Pearson, MR (Matthew)
<2009>
