1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: edm crashing in execute mode
Date: Fri, 20 Mar 2009 13:21:45 +0000 (GMT)
It was suggested to me to run gdb (thanks!)  However, I don't
know how to decode this, so I'm providing the dump.  BTW,
I'm running CentOS 5 and epics-3-14-10.  The exact code runs
on my Scientific Linux box.
Here's the dump:
(gdb) run -x BeamLine.edl
Starting program: /home/epics/Software/epics/extensions/bin/linux-x86/edm -x BeamLine.edl
[Thread debugging using libthread_db enabled]
[New Thread -1208432416 (LWP 18755)]
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread -1208432416 (LWP 18755)]
ProcessVariable::add_conn_state_callback (this=0x8c6da90, func=0x1cfe00 <xtdo_monitor_connect_state>, userarg=0x8c6f9e0) at ../dl_list.h:132
132             node->prev->next = node;
(gdb) bt
#0  ProcessVariable::add_conn_state_callback (this=0x8c6da90, func=0x1cfe00 <xtdo_monitor_connect_state>, userarg=0x8c6f9e0) at ../dl_list.h:132
#1  0x001d02d3 in activeXTextDspClass::activate (this=0x8c6f9e0, pass=2, ptr=0x8c6f9c0) at ../x_text_dsp_obj.cc:4315
#2  0x00d541f2 in activeGraphicClass::activate (this=0x8c6f9e0, pass=2, ptr=0x8c6f9c0, numSubObjects=0xbfccf2c8) at ../act_grf.cc:1841
#3  0x00d9b7f7 in activeGroupClass::activate (this=0x8c6eff8, pass=2, ptr=0x8c6efd8, numSubObjects=0xbfccf308) at ../group.cc:1733
#4  0x00d9b7f7 in activeGroupClass::activate (this=0x8c6e848, pass=2, ptr=0x8c6d7b0, numSubObjects=0xbfccf498) at ../group.cc:1733
#5  0x00d3a76c in activeWindowClass::execute (this=0x8c484c0) at ../act_win.cc:16161
#6  0x00d1da25 in appContextClass::applicationLoop (this=0x8bbc838) at ../app_pkg.cc:5532
#7  0x0804c2a7 in main (argc=3, argv=0xbfcd0ce4) at ../main.cc:2109
Any help would be greatly appreciated.
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039         office/lab/fax
http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
Prev: Re: edm crashing in execute mode J. Lewis Muir
Next: Re: RTEMS-mvme5500 BSP update Kate Feng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: edm crashing in execute mode John Sinclair
Next: RE: How to usr XtAddInput on CA's file descriptors? Jeff Hill
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
