1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: RTEMS-mvme5500 BSP update
To: Joel Sherrill <[email protected]>
Cc: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 19 Mar 2009 11:23:01 -0400
Joel Sherrill wrote:
Any chance of getting a patch to apply to the
RTEMS source base?
Yes, I can produce a patch for it and file a PR. My questions are:
1) Do you want the patch for RTEMS 4.9.1 only or for both
4.9.1 and 4.8.0 ?
2) There were lots of change, which were not related to any
bug.  It was just an attempt to be consistent with the shared code
in the PowerPC, which was originally written by Eric Valette.
Thus, I thought it would be easier if RTEMS takes the entire tar
file.  If you do not think so, then I  will produce a patch.   The patch
would appear overwhelmed, but the major updates are
really only the three things (e.g. bug fixes and PCI performance),
that were mentioned in my previous E-mail.
Please let me know what you think.  -- Kate
--joel sherrill
RTEMS
Kate Feng wrote:
The stable version of RTEMS-mvme5500 BSP is posted at
http://www.nsls.bnl.gov/facility/expsys/software/EPICS/
The "RTEMS-mvme5500 BSP v1.4.9.1", was tested
under RTEMS 4.9.1, and the "RTEMS-mvme5500 BSP v1.4.8.0"
was tested under RTEMS 4.8.0..
The highlights of the change are :
1)  Use the GT_GPP_Value register (0xf104) instead of the
GT_GPP_Interrupt_Cause register (0xf108) to monitor the cause
of the level sensitive interrupts. See irq/BSP_irq.c.
This is an unique solution which solves part of the bugs in
the BSP, which especially affects the 1GHz network driver.
2) There is no change in the 100 MHz network driver. Thus,
its performance stays the same.  Some bugs were fixed in the
1GHz network drivers (e.g. if_wm.c).
3)Enable "PCI Read Agressive Prefetch", "PCI Read Line Agressive Prefetch",
and "PCI Read Multiple Agressive Prefetch" to improve the performance of
the PCI based applications (e.g. 1GHz network driver). See pci/pci_interface.c.
However, performance is driven by applications.
There is no known bug at this point.  Any feedback which is related to
the RTEMS-mvme5500 BSP would be highly appreciated.
Hope this helps,
Kate
rtems-users mailing list
[email protected]
http://rtems.rtems.org/mailman/listinfo/rtems-users
RTEMS-mvme5500 BSP update Kate Feng
Re: RTEMS-mvme5500 BSP update Joel Sherrill
Prev: Re: RTEMS-mvme5500 BSP update Joel Sherrill
Next: RE: Prosilica cameras and bug in EPICS signal handlers Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: RTEMS-mvme5500 BSP update Kate Feng
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
