On Wed, 2009-03-18 at 11:42 +1100, Andrew C. Starritt wrote:
> Hi all,
> On a couple of IOCs, in the st.cmd file I start a number (7 or 9) SNL
> programs (well actually each IOC it is the same SNL program – with
> option +r
> and parameterised).
> Sometimes one or more random-ish instance fails to connect to
> all the PVs and essentially hangs. If I seqStop and restart the
> hung sequence program it runs as expected okay.
In your initialization state, you should check for PV connections:
ss turnOnOffStateSet {
state turnOnOffInitializationState {
entry{
seqLog("--> turnOnOffInitializationState\n");
p_deviceName=macValueGet("deviceName");
seqLog("deviceName=%s\n", p_deviceName);
when (pvConnectCount() == pvChannelCount()) {
seqLog("All channels connected\n");
delay(5);
seqLog("Reseting communication\n");
} state resetState
exit {
seqLog("<-- initializationState\n");
/* Buttons are intialized */
resetRqstdBO=0;pvPut(resetRqstdBO);
turnOffRqstdBO=0;pvPut(turnOffRqstdBO);
stndbyRqstdBO=0;pvPut(stndbyRqstdBO);
highVltgOnRqstdBO=0;pvPut(highVltgOnRqstdBO);
> I have some questions which I hope can get help with.
> The output from seqShow is:
> Program Name Thread ID Thread Name SS Name
> sncControl_Selection 0x32a75a0 sncControl_Selection cycle_magnets
> sncControl_Selection 0x32a2d70 sncControl_Selection cycle_magnets
> sncControl_Selection 0x32a4580 sncControl_Selection cycle_magnets
> sncControl_Selection 0x32a5d90 sncControl_Selection cycle_magnets
> sncControl_Selection 0x32aa5c0 sncControl_Selection cycle_magnets
> sncControl_Selection 0x32abfe0 sncControl_Selection cycle_magnets
> sncControl_Selection 0x32a8a30 sncControl_Selection cycle_magnets
> Is there an easy way to tell which instance is which?
That's an interesting question...
I am not sure you can do this through seqShow.
You can do this with the log file (seqLog) but it may be a little
tedious.
> Can I some how parameterise the program name, thread name or SS Name?
> I tried:
> program sncControl_Selection{NAME}
> and
> ss cycle_magnets{NAME}
> in the .stt file but neither would even compile.
In stt file:
program snovaTurnOnOff ("deviceName=(null)")
In ioc startup file:
seq snovaTurnOnOff,"deviceName=${SNOVA_DEVN},logfile=
${LOG_DIR}/${SNOVA_DEVN}-snovaTurnOnOff.log,debug=1"
> I also observed that the initial hang-up can is avoided by adding some
> sort of delay between the seq calls, e.g.:
> seq (sncControl_Selection,"NAME=SR03ID01, ILK_NAME=SR03II01")
> dbl * > /tmp/xx
> seq (sncControl_Selection,"NAME=SR04ID01, ILK_NAME=SR04II01")
> dbl * > /tmp/xx
> seq (sncControl_Selection,"NAME=SR05ID01, ILK_NAME=SR05II01")
> dbl * > /tmp/xx
> I have seen this on both epics base 3.14.8.2 with seq-2.0.11 on 4 year
> old
> redhawk Linux system and using epics base 3.14.9 with seq-2.0.11 on a
> newish
> CentOs 5.1 system. Any thoughts as to what is happening?
> If the only solution is a small delay, is there a standard IOC shell
> sleep
> command I could use instead?
In iocsh Try:
help
help epicsThreadSleep
epicsThreadSleep(5)
> Regards
> Andy
> Andrew Starritt, Principal Controls Engineer, Australian Synchrotron
> 800 Blackburn Road, Clayton, Victoria 3168
> ph: (03) 8540 4164 , fax: (03) 8540 4200
> mailto:[email protected],
> http://www.synchrotron.org.au
> This message and any attachments may contain proprietary or
> confidential information. If you are not the intended recipient or you
> received the message in error, you must not use, copy or distribute
> the message. Please notify the sender immediately and destroy the
> original message. Thank you.
- Re: Starting multiple SNL programs Martin L. Smith
- Starting multiple SNL programs Andrew C. Starritt
Re: Building Epics 3.14.10 on Linux Andrew Johnson
epics GUIs (update) Emmanuel Mayssat
<2009>
<2009>
