1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: weird behaviour of SNL test program running on Soft IOC on LINUX
To: [email protected], Oleg Makarov <[email protected]>
Cc: "Stepanov, Sergey" <[email protected]>
Date: Tue, 17 Mar 2009 11:36:30 -0500
Hi Oleg,
On Monday 16 March 2009 16:43:26 Oleg Makarov wrote:
> It is strange though that it does not work without explicit pvFlush()
> calls. If  "+a" option is not set for snc compiler, one would expect
> synchronous IO to be performed.
I suspect part of the problem might be that you're calling epicsThreadSleep()
inside the action statements, which completely freezes the sequence program
during that delay period.  This almost always turns out to be the wrong thing
to do since the sequence program can't break out of that delay if something
unexpected happens.  You should instead call the delay() function inside a
when() statement, which also permits the sequencer to perform other actions
while it's waiting.  I would recommend changing your program to look more
like this instead (not tested), which might help:
ss main {
  state init {
    when (pvConnectCount() == pvChannelCount()) {
    } state connected
  state connected {
    when (1)
      strcpy(str_cmd, "I522");
      pvPut(str_cmd);
      pvFlush();
    } state action522
  state action522 {
    when (delay(1.0)) {
      pvGet(str_rsp);
    } state getting
  state getting {
    when (delay(1.0)) {
      printf("str_rsp = %s \n", str_rsp);
      strcpy(str_cmd, "I521");
      pvPut(str_cmd);
      pvFlush();
    } state action521
  state action521 {
    when (pvConnectCount() != pvChannelCount()) {
    } state init
    when (delay(1.0)) {
    } state connected
Note that you can easily add the ability to react to channel disconnection in
the action522 and getting states if you wish.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
weird behaviour of SNL test program running on Soft IOC on LINUX Oleg Makarov
Re: weird behaviour of SNL test program running on Soft IOC on LINUX J. Lewis Muir
Re: weird behaviour of SNL test program running on Soft IOC on LINUX Oleg Makarov
Prev: Re: weird behaviour of SNL test program running on Soft IOC on LINUX Oleg Makarov
Next: Re: weird behaviour of SNL test program running on Soft IOC on LINUX Oleg Makarov
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: weird behaviour of SNL test program running on Soft IOC on LINUX Pete Jemian
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
