Hi Maren,
On Monday 16 March 2009 20:23:51 Maren Purves wrote:
> Can you have several records talk to the same piece of hardware without
> manually disconnecting? (I'm sure it depends on the hardware, but I can
> think of a few where that wouldn't work - and even if you disconnect
> manually, how do you control which record connects the next time?).
Many device support layers work Ok with multiple records pointing to the same
hardware address, although obviously some may have been written without that
in mind and could break if you do that. I guess the main source of problems
could be asynchronous devices, but in many cases the underlying driver
support is able to handle multiple record types anyway and this generally
requires authors to put the necessary locking and queuing infrastructure into
the support anyway.
Of course having multiple output records driving the same signal could be a
recipe for user confusion if the device doesn't have readback and value
update functionality, so this isn't really recommended.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
- how to change the MEAN without reboot IOC? 汪启胜
- 答复: how to change the MEAN without reboot IOC? 汪启胜
- Re: ´ð¸´: how to change the MEAN without reboot IOC? Maren Purves
RE: Keithley 2000 multimeter support? Elder Matias
Re: weird behaviour of SNL test program running on Soft IOC on LINUX Oleg Makarov
<2009>
RE: Keithley 2000 multimeter support? Mark Rivers
RE: how to change the MEAN without reboot IOC? Graham Cross
<2009>
