Hello All,
I'm a newbie and I can't seem to get the example ioc working.
I must be missing something - probably something simple but I'm stuck and any guidance would be very much appreciated. My guess is it has something to do with "Error 2" during the application make - the result is that the example application is simply not created or compiled as far as I can tell. Following are the basic step I took using the cygwin platform:
# unzip to c:/epics
$ export EPICS_HOST_ARCH=cygwin-x86
$ cd epics/base-3.14.10 $ make $ echo $EPICS_HOST_ARCH
# make directory
$ mkdir app
$ cd app $ c:/epics/base-3.14.10/bin/cygwin-x86/makeBaseApp.pl -t example myapp $ c:/epics/base-3.14.10/bin/cygwin-x86/makeBaseApp.pl -i -t example myapp # from developers guide : 2.2.4 Sequencer Example
# The sequencer is now supported as an unbundled product. The example includes an example state notation program; # sncExample.stt. As created by makeBaseApp the example is not built or executed. # Before sncExample.st can be built, the sequencer must be built using the same version of base that the example uses. # To build sncExample edit the following files: # • configure/RELEASE - Set SNCSEQ to the location of the sequencer. # • iocBoot/iocmyexample/st.cmd - Remove the comment character # from # #seq sncExample,"user=<user" # The Makefile contains commands for building sncExample as a component of the ioc application and as a standalone # application, i.e. an application that does not use an epics database. $ make make -C ./configure install
make[1]: Entering directory `/cygdrive/c/epics/base-3.14.10/app/configure' perl c:/epics/base-3.14.10/bin/cygwin-x86/convertRelease.pl checkRelease perl c:/epics/base-3.14.10/bin/cygwin-x86/makeMakefile.pl O.cygwin-x86 ../.. mkdir O.Common make -C O.cygwin-x86 -f ../Makefile TOP=../.. T_A=cygwin-x86 install make[2]: Entering directory `/cygdrive/c/epics/base-3.14.10/app/configure/O.cygwin-x86' make[2]: Nothing to be done for `install'. make[2]: Leaving directory `/cygdrive/c/epics/base-3.14.10/app/configure/O.cygwin-x86' make[1]: Leaving directory `/cygdrive/c/epics/base-3.14.10/app/configure' make -C ./myappApp install make[1]: Entering directory `/cygdrive/c/epics/base-3.14.10/app/myappApp' make -C ./src install make[2]: Entering directory `/cygdrive/c/epics/base-3.14.10/app/myappApp/src' perl c:/epics/base-3.14.10/bin/cygwin-x86/makeMakefile.pl O.cygwin-x86 ../../.. mkdir O.Common make -C O.cygwin-x86 -f ../Makefile TOP=../../.. T_A=cygwin-x86 install make[3]: Entering directory `/cygdrive/c/epics/base-3.14.10/app/myappApp/src/O.cygwin-x86' make[3]: Leaving directory `/cygdrive/c/epics/base-3.14.10/app/myappApp/src/O.cygwin-x86' make[2]: *** [install.cygwin-x86] Error 2 make[2]: Leaving directory `/cygdrive/c/epics/base-3.14.10/app/myappApp/src' make[1]: *** [src.install] Error 2 make[1]: Leaving directory `/cygdrive/c/epics/base-3.14.10/app/myappApp' make: *** [myappApp.install] Error 2 $ cd iocBoot/iocmyapp
$ c:/epics/base-3.14.10/bin/cygwin-x86/myexample st.cmd bash: c:/epics/base-3.14.10/bin/cygwin-x86/myexapp: no such file or directory
Ideas? Thanks,
-Jefffrey Holt
ANJ, 31 Jan 2014 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
