1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Help building EPICS 3.14.9 for RTEMS
To: Tech-talk <[email protected]>
Date: Mon, 16 Mar 2009 18:05:37 -0400
Thanks Eric and Till for the prompt reply. I added
 unexport GCC_EXEC_PREFIX  in CONFIG_SITE.Common.RTEMS
That works!
until I get to osdInterrupt.c.   What's up with rtems_unsigned32?
Thanks in advance,
Sue
/usr/csite/pubtools/rtems/4.9.1/bin/i386-rtems4.9-gcc --pipe -B/usr/csite/pubtools/rtems/4.9.1/i386-rtems4.9/pc386/lib/ -specs bsp_specs -qrtems -fasm -c -mtune=i386 -ansi -O2 -g -g -Wall -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/RTEMS -I../../../include ../../../src/libCom/osi/os/RTEMS/osdInterrupt.c ../../../src/libCom/osi/os/RTEMS/osdInterrupt.c: In function 'InterruptContextMessageDaemon': ../../../src/libCom/osi/os/RTEMS/osdInterrupt.c:68: error: 'rtems_unsigned32' undeclared (first use in this function) ../../../src/libCom/osi/os/RTEMS/osdInterrupt.c:68: error: (Each undeclared identifier is reported only once ../../../src/libCom/osi/os/RTEMS/osdInterrupt.c:68: error: for each function it appears in.) ../../../src/libCom/osi/os/RTEMS/osdInterrupt.c:68: error: expected ';' before 'size' ../../../src/libCom/osi/os/RTEMS/osdInterrupt.c:83: error: 'size' undeclared (first use in this function)
gmake[3]: *** [osdInterrupt.o] Error 1
Re: Help building EPICS 3.14.9 for RTEMS Till Straumann
Prev: Re: weird behaviour of SNL test program running on Soft IOC on LINUX Pete Jemian
Next: Re: weird behaviour of SNL test program running on Soft IOC on LINUX Sergey Stepanov
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Help building EPICS 3.14.9 for RTEMS Eric Norum
Next: Re: Help building EPICS 3.14.9 for RTEMS Till Straumann
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
