1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Help building EPICS 3.14.9 for RTEMS
To: Sue Witherspoon <[email protected]>
Cc: Tech-talk <[email protected]>
Date: Mon, 16 Mar 2009 15:56:09 -0500
On Mar 16, 2009, at 2:43 PM, Sue Witherspoon wrote:
I'm trying to build EPICS 3.14.9 for RTEMS-pc386 and I get the following error. It appears that the CONFIG files don't include the cross-compiler include directory. I can't seem to figure out which config file to add the necessary include path. My environment is the following:
EPICS 3.14.9
RTEMS 4.9.1
HOST Linux Red-Hat 4.0 ia32
gcc 4.3.2
Any help and clues would be greatly appreciated.
Sue Witherspoon
TJNAF
Accelerator Software Controls
gmake -C O.RTEMS-pc386 -f ../Makefile TOP=../../.. T_A=RTEMS-pc386 install gmake[3]: Entering directory `/a/devsite/dvlepics/epics/R3.14.9.J1/ src/libCom/O.RTEMS-pc386' /usr/csite/pubtools/rtems/4.9.1/bin/i386-rtems4.9-gcc --pipe -B/usr/ csite/pubtools/rtems/4.9.1/i386-rtems4.9/pc386/lib/ -specs bsp_specs -qrtems -fasm -c -mtune=i386 -ansi - O2 -g -g -Wall -I. -I.. -I../../../src/libCom/bucketLib - I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/ libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/ cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ ellLib -I../../../src/libCom/env -I../../../src/libCom/error - I../../../src/libCom/fdmgr -I../../../src/libCom/freeList - I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../ src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/ libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd - I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../ include/os/RTEMS -I../../../include ../../../src/libCom/ bucketLib/bucketLib.c
 Here's the command that I get for that source file:
/usr/local/rtems/rtems-4.9.1/bin/i386-rtems4.9.1-gcc --pipe -B/usr/ local/rtems/rtems-4.9.1/i386-rtems4.9.1/pc386/lib/ -specs bsp_specs - qrtems -fasm -c -mtune=i386 -DUNIX -O2 -g -g - Wall -I. -I../O.Common -I. -I../../../src/libCom/osi/os/ RTEMS -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/ default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast - I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates - I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/ libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr - I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../ src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/ macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../ src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/ tsDefs -I../../../include/os/RTEMS -I../../../include ../../../ src/libCom/bucketLib/bucketLib.c
Possibility 1 -- the definitions of RTEMS_BASE and RTEMS_VERSION are out of sync. Here's what I have in configure/os/ CONFIG_SITE.Common.RTEMS
RTEMS_BASE=/usr/local/rtems/rtems-4.9.1
RTEMS_VERSION=4.9.1
Possibility 2 --something in the RTEMS tool chains has been moved to a location other than the '--prefix' value used to build the tools. There are ways to work around this (GCC_EXE_PREFIX, etc.) but it may be easier to just rebuild your toolchain with the correct --prefix.
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
Help building EPICS 3.14.9 for RTEMS Sue Witherspoon
Prev: Relational Database Poll Mike Forster
Next: Re: weird behaviour of SNL test program running on Soft IOC on LINUX Oleg Makarov
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Help building EPICS 3.14.9 for RTEMS Till Straumann
Next: RE: Help building EPICS 3.14.9 for RTEMS Sue Witherspoon
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
