1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: weird behaviour of SNL test program running on Soft IOC on LINUX
To: "Mark Rivers" <[email protected]>, "EPICS tech-talk" <[email protected]>
Cc: [email protected], "Stepanov, Sergey" <[email protected]>
Date: Mon, 16 Mar 2009 15:08:00 -0500
Hi Mark,
I tried the test with this fix. The problem is not resolved by epicsThreadSleep code change in the osdThread.c.
CA requests are not being send out  as they arise, some buffering of the requests occurs to make network communication more efficient. If you look at the camonitor output, it shows a 3-second period, exactly as expected.
Are there way to force CA requests to go out as they arise, with no buffering?
Oleg
----- Original Message -----
Sent: Monday, March 16, 2009 12:10 PM
Subject: RE: weird behaviour of SNL test program running on Soft IOC on LINUX
Hi Oleg,
I have seen a problem that might be related.
Would the symptoms you see be consistent with epicsThreadSleep() simply returning too soon?
I was getting that problem when my Linux IOC was linked with some code that uses the new Posix 1.b timer routines.  Those routines cause SIGALRM signals to be generated, potentially very frequently.  SIGALRM signals will cause the Posix nanosleep() function to return immediately with errno=EINTR.  nanosleep is what epicsThreadSleep uses on Linux.
I modified the epicsThreadSleep code in libCom/osi/os/posix/osdThread.c as follows:
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/libCom/osi/os/posix/osdThread.c,v
retrieving revision 1.67.2.32
diff -u -r1.67.2.32 osdThread.c
--- osdThread.c 6 Aug 2008 16:54:25 -0000       1.67.2.32
+++ osdThread.c 16 Mar 2009 17:08:28 -0000
@@ -606,7 +606,8 @@
     delayTime.tv_sec = (time_t)seconds;
     nanoseconds = (seconds - (double)delayTime.tv_sec) *1e9;
     delayTime.tv_nsec = (long)nanoseconds;
-    nanosleep(&delayTime,&remainingTime);
+    while(nanosleep(&delayTime,&remainingTime) == -1)
+       delayTime = remainingTime;
It would be interesting to see if this fixes your problem.  Could your soft IOC be using the Posix 1.b timer routines?
From: [email protected] [mailto:[email protected]] On Behalf Of Oleg Makarov
Sent: Monday, March 16, 2009 11:04 AM
To: EPICS tech-talk
Cc: [email protected]; Stepanov, Sergey
Subject: weird behaviour of SNL test program running on Soft IOC on LINUX
A small SNL test program strangely misbehaves when it being run on Soft IOC on LINUX.
Under VxWorks this SNL test program program behaves as expected.
program test("name=my_test, dev=23b:GO:mom:")
  %%#include <string.h>
  string str_rsp; assign str_rsp to "{dev}StrRsp";
  string str_cmd; assign str_cmd to "{dev}StrCmd";
  ss main {
    state tst {
      when(pvConnectCount() == pvChannelCount()) {
        strcpy (str_cmd, "I522");
        pvPut(str_cmd); epicsThreadSleep(1.0);
        pvGet (str_rsp); epicsThreadSleep(1.0);
        printf ("str_rsp = %s \n", str_rsp);
        strcpy (str_cmd, "I521");
    } state tst
This program interacts with device using two EPICS PV strings:
1)  writes a command "I522" and sleeps one second
2) reads a response and sleeps one second
3) prints a response at IOC console
4) writes a command "I521" and sleeps one second
The program repeats this sequence periodically.
being run under the VxWorks OS program behaves exactly as expected:
23b:ioc2> seq &test, "name=my_test, mtr=23b:GO:mom:"
SEQ Version 2.0.12: Mon Feb 9 13:16:21 2009
Spawning state program "test", thread 0x1ee970f0: "my_test"
value = 518615280 = 0x1ee970f0
23b:ioc2> str_rsp = 378.88
str_rsp = 378.88
str_rsp = 378.88
str_rsp = 378.88
str_rsp = 378.88
str_rsp = 378.88
str_rsp = 378.88
camonitor connected to these two PV strings shows timing as expected:
gmca@mar3:~ 6> camonitor 23b:GO:mom:StrCmd 23b:GO:mom:StrRsp
23b:GO:mom:StrCmd 2009-03-13 18:12:19.025831 I522
23b:GO:mom:StrRsp 2009-03-13 18:12:19.042497 378.88
23b:GO:mom:StrCmd 2009-03-13 18:12:21.025831 I521
23b:GO:mom:StrRsp 2009-03-13 18:12:21.025831 100
23b:GO:mom:StrCmd 2009-03-13 18:12:22.025831 I522
23b:GO:mom:StrRsp 2009-03-13 18:12:22.025831 378.88
23b:GO:mom:StrCmd 2009-03-13 18:12:24.025831 I521
23b:GO:mom:StrRsp 2009-03-13 18:12:24.025831 100
23b:GO:mom:StrCmd 2009-03-13 18:12:25.025830 I522
23b:GO:mom:StrRsp 2009-03-13 18:12:25.025830 378.88
23b:GO:mom:StrCmd 2009-03-13 18:12:27.025830 I521
23b:GO:mom:StrRsp 2009-03-13 18:12:27.025830 100
being run under Soft IOC on LINUX strange things happen - on the concole it prints a string corresponding to the responce on the second command and sometimes it prints a string with the first command "I522":
str_rsp = 100
str_rsp = 100
str_rsp = I522
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = I522
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = I522
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = I522
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = I522
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = I522
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = I522
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = I522
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = 100
str_rsp = I522
str_rsp = 100
str_rsp = 100
camonitor connected to these two PV strings also shows a strange timing - two commands get posted without time delays:
23b:GO:mom:StrCmd 2009-03-13 18:27:02.628072 I522
23b:GO:mom:StrCmd 2009-03-13 18:27:04.978072 I521
23b:GO:mom:StrCmd 2009-03-13 18:27:06.628072 I522
23b:GO:mom:StrRsp 2009-03-13 18:27:06.628072 378.88
23b:GO:mom:StrCmd 2009-03-13 18:27:08.628072 I521
23b:GO:mom:StrCmd 2009-03-13 18:27:08.628072 I522
23b:GO:mom:StrRsp 2009-03-13 18:27:08.628072 100
23b:GO:mom:StrCmd 2009-03-13 18:27:11.644738 I521
23b:GO:mom:StrCmd 2009-03-13 18:27:11.644738 I522
23b:GO:mom:StrCmd 2009-03-13 18:27:14.644738 I521
23b:GO:mom:StrCmd 2009-03-13 18:27:14.644738 I522
23b:GO:mom:StrCmd 2009-03-13 18:27:17.644738 I521
23b:GO:mom:StrCmd 2009-03-13 18:27:17.644738 I522
23b:GO:mom:StrCmd 2009-03-13 18:27:20.644738 I521
23b:GO:mom:StrCmd 2009-03-13 18:27:20.644738 I522
23b:GO:mom:StrCmd 2009-03-13 18:27:23.661404 I521
23b:GO:mom:StrCmd 2009-03-13 18:27:23.661404 I522
Any ideas on how to correct this problem with SNL test program running on Soft IOC under LINUX OS?
Oleg A. Makarov,
Beamline Instrumentation Scientist
Argonne National Laboratory
9700 South Cass Avenue
Argonne, IL 60439-4861
Phone 630 252 0668
Fax 630 252 0667
Re: weird behaviour of SNL test program running on Soft IOC on LINUX J. Lewis Muir
weird behaviour of SNL test program running on Soft IOC on LINUX Oleg Makarov
RE: weird behaviour of SNL test program running on Soft IOC on LINUX Mark Rivers
Prev: Help building EPICS 3.14.9 for RTEMS Sue Witherspoon
Next: Re: Help building EPICS 3.14.9 for RTEMS Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: weird behaviour of SNL test program running on Soft IOC on LINUX Mark Rivers
Next: Re: weird behaviour of SNL test program running on Soft IOC on LINUX J. Lewis Muir
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
