Here is the complete log
pratik@pratik:~$ export EPICS_HOST_ARCH=linux-x86
pratik@pratik:~$ cd /home/pratik/epics/extensions/src/edm/
pratik@pratik:~/epics/extensions/src/edm$ make
make -C ./util install
make[1]: Entering directory `/home/pratik/epics/extensions/src/edm/util'
make -C O.linux-x86 -f ../Makefile TOP=../../../.. T_A=linux-x86 install
make[2]: Entering directory `/home/pratik/epics/extensions/src/edm/util/O.linux-x86'
make[2]: Nothing to be done for `install'.
make[2]: Leaving directory `/home/pratik/epics/extensions/src/edm/util/O.linux-x86'
make[1]: Leaving directory `/home/pratik/epics/extensions/src/edm/util'
make -C ./lib install
make[1]: Entering directory `/home/pratik/epics/extensions/src/edm/lib'
make[2]: Entering directory `/home/pratik/epics/extensions/src/edm/lib/O.linux-x86'
/usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall -DSINGLE_THREADED=1 -D__epics__=1 -m32 -g -fPIC -I. -I../O.Common -I. -I.. -I../../../../include/edm/os/Linux -I../../../../include/edm -I/home/pratik/epics/base/include/os/Linux -I/home/pratik/epics/base/include -I../../../../include -I../../util -I../../lib -I../../pvlib -I/usr/X11R6/include -I/usr/X11R6/include/X11 ../app_pkg.cc
In file included from ../pv_factory.h:11,
from ../pvColor.h:23,
from ../act_grf.h:31,
from ../bindings.h:26,
from ../act_win.h:43,
from ../app_pkg.h:36,
from ../app_pkg.cc:19:
../hashtable.h: In member function ?void Hashtable<T, o, N>::info()?:
../hashtable.h:177: error: ?cout? was not declared in this scope
../app_pkg.cc: In function ?void manageComponents(char*, char*)?:
../app_pkg.cc:308: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:315: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:486: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:493: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:590: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:693: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc: In function ?void managePvComponents(char*, char*)?:
../app_pkg.cc:764: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:771: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:925: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:1019: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:1122: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc: In function ?void ctlPvUpdate(ProcessVariable*, void*)?:
../app_pkg.cc:1189: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc: In function ?void selectPath_cb(_WidgetRec*, void*, void*)?:
../app_pkg.cc:1293: warning: unused variable ?item?
../app_pkg.cc: In function ?void abort_cb(_WidgetRec*, void*, void*)?:
../app_pkg.cc:1647: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc: In function ?void exit_cb(_WidgetRec*, void*, void*)?:
../app_pkg.cc:1675: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:1690: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc: In function ?void shutdown_cb(_WidgetRec*, void*, void*)?:
../app_pkg.cc:1746: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc: In function ?void help_cb(_WidgetRec*, void*, void*)?:
../app_pkg.cc:1977: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:1981: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:2002: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:2025: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc: At global scope:
../app_pkg.cc:2083: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc: In member function ?void appContextClass::getFilePaths()?:
../app_pkg.cc:2478: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:2551: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:2599: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:2614: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:2548: warning: ignoring return value of ?int chdir(const char*)?, declared with attribute warn_unused_result
../app_pkg.cc:2594: warning: ignoring return value of ?int chdir(const char*)?, declared with attribute warn_unused_result
../app_pkg.cc:2611: warning: ignoring return value of ?char* getcwd(char*, size_t)?, declared with attribute warn_unused_result
../app_pkg.cc: In member function ?void appContextClass::buildSchemeList()?:
../app_pkg.cc:2843: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:2850: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:2976: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc: In member function ?int appContextClass::schemeExists(char*, char*, char*)?:
../app_pkg.cc:3132: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:3134: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc: In member function ?void appContextClass::getScheme(char*, char*, char*, char*, int)?:
../app_pkg.cc:3175: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:3177: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc: In member function ?void appContextClass::createMainWindow()?:
../app_pkg.cc:3513: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:3515: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:3577: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:3612: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:3699: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:3734: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:3775: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc: In member function ?int appContextClass::startApplication(int, char**, int, int, int)?:
../app_pkg.cc:4549: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:4593: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:4647: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:4656: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:4667: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:4669: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:4672: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:4675: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:4686: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:4689: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:4701: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:4716: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:4763: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc: In member function ?void appContextClass::applicationLoop()?:
../app_pkg.cc:5444: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc: In member function ?void appContextClass::postMessage(char*)?:
../app_pkg.cc:5544: warning: format not a string literal and no format arguments
../app_pkg.cc:5546: warning: format not a string literal and no format arguments
../app_pkg.cc: In member function ?void appContextClass::xSynchronize(int)?:
../app_pkg.cc:5739: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc: In member function ?void appContextClass::performShutdown(FILE*)?:
../app_pkg.cc:5801: warning: deprecated conversion from string constant to ?char*?
make[2]: *** [app_pkg.o] Error 1
make[2]: Leaving directory `/home/pratik/epics/extensions/src/edm/lib/O.linux-x86'
make[1]: *** [install.linux-x86] Error 2
make[1]: Leaving directory `/home/pratik/epics/extensions/src/edm/lib'
make: *** [lib.install] Error 2
- DIfficulty with Libusb with EPICS Mehta, Pratik
Re: Difficulty with edm installation Pete Jemian
RE: Inter-IOC link problems Jeff Hill
<2009>
<2009>
