1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: FW: edm version 1-11-1zl and fedora 10
Cc: [email protected]
Date: Wed, 11 Mar 2009 11:07:00 -0400
On a related note, we found that on our RHEL 4 systems we had to remove the "unscaled" qualifiers from fs/config to get full EDM font functionality (specifically the rotated fonts used by some widgets).
--Brian
John Sinclair wrote:
Chris,
I found this comment in an old mail message:
However, I managed to solve the problem I was having with xfs in FC9. Just in case someone else asks you: as you said, it's a matter of editing /etc/X11/fs/config after installing xorg-x11-xfs via yum. Although the default config looks like it should work, it seems it is necessary to change the "catalogue =" line to its equivalent in FC6, that is:
catalogue = /usr/share/X11/fonts/misc:unscaled,
/usr/share/X11/fonts/75dpi:unscaled,
/usr/share/X11/fonts/100dpi:unscaled,
/usr/share/X11/fonts/Type1,
/usr/share/X11/fonts/TTF,
/usr/share/fonts/default/Type1,
I might be something to examine.
John
Dropp, Christopher wrote:
Greetings,
We are working to get edm running on fedora 10 and were able to get it to compile with little problem but getting it to run has been another story. The trouble is with the fonts...has anyone else reported any problems with edm on f10? We have a working version, 1-11-1d, that uses the 110, version 1 font file format, running on f8 but when I try this font file version or version 3 edm has a font init error. The f8 machine and the f10 machine have the same available fonts but for some reason things don't work on the f10 machine. Your thoughts would be much appreciated!
Thank you and have a great day!
Chris
Christopher Dropp Biology Department Brookhaven National Laboratory Upton, NY 11973 Phone: 631-344-3421
Pager: 631-344-3456 pgr #: 7408 Fax: 631-344-2741 E-Mail: [email protected]
Brian S. Bevins, PE
Computer Scientist / Mechanical Engineer
Thomas Jefferson National Accelerator Facility
    "Nothing in all the world is more dangerous than
     sincere ignorance and conscientious stupidity."
                                    --Martin Luther King Jr.
FW: edm version 1-11-1zl and fedora 10 Dropp, Christopher
Re: FW: edm version 1-11-1zl and fedora 10 John Sinclair
Prev: RE: Looking for feedback on what epics users require Ahed Al adwan
Next: epics for stanford amp or Iseg supply Leicester, PJ (Pete)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: FW: edm version 1-11-1zl and fedora 10 John Sinclair
Next: makeBaseApp Zhichu Chen
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
