The deployment scenario for these power supplies will likely factor into
any given customer's requirements. If there are only a few supplies
being used, then as Tim Mooney pointed out, the simplest integration
technique is to provide a turn-key IOC. But as Ernest pointed out, there
will inevitably be many custom tweaks desired for the turn-key IOC
config, so much of the configuration (and possibly code) needs to be
exposed.
If there will be hundreds of power supplies being used, then things get
a bit more complicated. If each supply has an IOC, then each controlling
Channel Access client will have to make hundreds of TCP connections.
This can be managed through an EPICS PV Gateway, but the feasibility
depends on a customers network layout, and whether or not they want to
introduce PV Gateways into their system.
Probably the most flexible approach is to provide EPICS device support
and a template of EPICS records that can control your supply. In the
case of hundreds of power supplies, for example, the customer could put
your UDP traffic on a private subnet, and have just a couple of IOCs
running all of the supplies. Then Channel Access clients could access
all the supplies with just a couple TCP connections (on a separate
subnet). This approach has the added advantage of not having to package
up an entire IOC (and reduce your exposure to possible bugs that arise
in IOC Core).
just some thoughts - there is lots to evaluate
Claude
Pawel Kowalski - BiRa Systems Inc. wrote:
Hello,
My company is researching providing an epics IOC with some of our
power supplies. I would like to get some feedback from the epics
community on what exactly would be required. First let me start off by
saying that epics is still a new area for me so hopefully these
questions aren't dumb, we are still in the early research stages on this.
What we would like to do is provide a system with each device that
will host an EPICS IOC. This will be a vxWorks based system running
epics base 3.14. This system will communicate with our device using
ethernet and convert standard UDP commands that our devices work on to
process variables. So for example our clients would now have a process
variable they could use to monitor or set the voltage of a power
supply (IE: powersys:voltage).
For the client side we would like to develop a LabVIEW interface, we
would most likely not be developing a custom C/C++ application for the
client.
Would this be adequate for most epics users or would more be required
to integrate this into an existing epics network? Would people use the
LabVIEW client we develop or do most labs use their own custom
software to control/monitor epics enabled equipment? Any feedback from
the community would be greatly appreciated, thank you.
- Looking for feedback on what epics users require Pawel Kowalski - BiRa Systems Inc.
RE: Looking for feedback on what epics users require Dalesio, Leo
Two EDM questions Szalata, Zenon M.
<2009>
Re: Looking for feedback on what epics users require Tim Mooney
Re: Looking for feedback on what epics users require Ralph Lange
<2009>
ANJ, 31 Jan 2014 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
