1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Problem with cothread-1-12 on MacOSX (Leopard)
To: Juan Carlos Guzman <[email protected]>
Date: Tue, 10 Mar 2009 10:34:51 +0000 (GMT)
On Tue, 10 Mar 2009, Michael Abbott wrote:
> On Tue, 10 Mar 2009, Abbott, MG (Michael) wrote:
> 	stdin, ... is a device and therefore doesn't work with darwin's
> 	poll. In this case poll just spews POLLNVAL
> Ok, so poll() on Darwin is busted.
> Looks like I'll have to code up an emulation of poll() using select() and
Juan,
Can you try the attached patch and let me know how things behave.
This is a quick and dirty hack, if it's ok I'll work up a proper release.
The problem with using select is that its error handling is lousy: if any
file handle is invalid I have to back out and individually call select()
on each handle, one by one, to find the offending ones.
	Michael
Index: cothread/coselect.py
--- cothread/coselect.py	(revision 28616)
+++ cothread/coselect.py	(working copy)
@@ -101,6 +101,55 @@
         return []
+def poll_block_select(poll_list, timeout = None):
+    '''This reimplements the functionality of poll_block but using select
+    instead.  This is intended to be used
+        1. where poll is not available
+        2. on OSX where poll is broken, does not work on all file descriptors,
+           in particular not on stdin.
+    flag_mapping = (POLLIN, POLLOUT, POLLPRI)
+    # Generate list of arguments for select from poll arguments.
+    selects = ([], [], [])
+    for file, events in poll_list:
+        for wtd, event in zip(selects, flag_mapping):
+            if events & event:
+                wtd.append(file)
+    result = {}
+    try:
+        selected = _select.select(*selects + (timeout,))
+    except _select.error:
+        # Oh dear.  *Something* is wrong, but I don't know which file handle
+        # is broken.  This is not good: going to have to probe each file in
+        # turn to find out.
+                    wtd.append(file)
+            try:
+                selected = _select.select(*selects + (0,))
+                # Still don't really know what's wrong, but it's a safe bet
+                # the problem is the file handle.
+                result[file] = POLLNVAL
+            else:
+                for wtd, event in zip(selected, flag_mapping):
+                    if file in wtd:
+                        result[file] = result.get(file, 0) | event
+    else:
+        # Map select result into poll list result.
+                if file in wtd:
+    return result.items()
+poll_block = poll_block_select
 def _compute_poll_list(poll_queue):
     '''Computes a list of (file, event_mask) pairs of all descriptor events
     of interest, according to the given poll_queue, which is itself a
Re: Problem with cothread-1-12 on MacOSX (Leopard) Juan Carlos Guzman
RE: Problem with cothread-1-12 on MacOSX (Leopard) Abbott, MG (Michael)
RE: Problem with cothread-1-12 on MacOSX (Leopard) Michael Abbott
Prev: RE: Problem with cothread-1-12 on MacOSX (Leopard) Michael Abbott
Next: Re: FW: edm version 1-11-1zl and fedora 10 John Sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Problem with cothread-1-12 on MacOSX (Leopard) Juan Carlos Guzman
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
