While installing epics base on ubuntu linux I got the following error while running make
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_READLINE -m32 -g -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs !
-I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/default/epicsReadline.c
../../../src/libCom/osi/os/default/epicsReadline.c:76:31: error: readline/readline.h: No such file or directory
../../../src/libCom/osi/os/default/epicsReadline.c:77:30: error: readline/history.h: No such file or directory
../../../src/libCom/osi/os/default/epicsReadline.c: In function ?epicsReadlineBegin?:
../../../src/libCom/osi/os/default/epicsReadline.c:101: warning: implicit declaration of function ?stifle_history?
../../../src/libCom/osi/os/default/epicsReadline.c:102: warning: implicit declaration of function ?rl_bind_key?
../../../src/libCom/osi/os/default/epicsReadline.c:102: error: ?rl_insert? undeclared (first use in this function)
../../../src/libCom/osi/os/default/epicsReadline.c:102: error: (Each undeclared identifier is reported only once
../../../src/libCom/osi/os/default/epicsReadline.c:102: error: for each function it appears in.)
../../../src/libCom/osi/os/default/epicsReadline.c: In function ?epicsReadline?:
../../../src/libCom/osi/os/default/epicsReadline.c:124: warning: implicit declaration of function ?readline?
../../../src/libCom/osi/os/default/epicsReadline.c:124: warning: assignment makes pointer from integer without a cast
../../../src/libCom/osi/os/default/epicsReadline.c:162: warning: implicit declaration of function ?add_history?
make[3]: *** [epicsReadline.o] Error 1
make[3]: Leaving directory `/home/pratik/epics/base-3.14.10/src/libCom/O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `/home/pratik/epics/base-3.14.10/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/home/pratik/epics/base-3.14.10/src'
make: *** [src.install] Error 2
I guess some required packages may be missing,
Can anyone tell me which ?
Thank you,
Confused Pratik
- Re: EPICS for USB devices Pete Jemian
- EPICS for USB devices Mehta, Pratik
synApps 5.4 release Tim Mooney
<2009>
RE: EPICS for USB devices Mark Rivers
<2009>
