1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: caget with an array of space-containing strings
To: Ralph Lange <[email protected]>
Date: Fri, 27 Feb 2009 10:26:01 -0500
On 2/26/09 7:23 PM, Ralph Lange wrote:
> Hi,
> In general I would second Andrew's statement. Looping over CA command
> line tool calls would be bad behaviour in terms of CA.
Hi, Ralph.
I agree w/ Andrew's statement too, but I think it just depends on what
Carl is trying to do.  I think sometimes using caget (and other command
line tools) for scripting is fine for the job.  Maybe I want to write
something very quickly that will poll the IOC via caget once every 5
minutes saving the result to a file.  Or maybe I want to pass that caget
output to another program to do something else.
Even though caget and friends are designed for human consumption, if
the change is not that hard to make, I think it's worth it to enable the
output to be easily parsed.
> I have to admit, though, that arrays of strings with embedded spaces
> break one of the command line tools' underlying ideas: caput understands
> the caget return value of the same PV.
> So, an command line option to change the separator could be a feasible
> solution, or quoting those strings, or both. Any preferences?
Is there a character that is not allowed to appear in an EPICS
string...perhaps the null character (\000)?
Assuming there is such a character (and I know, sometimes such a
character is not necessary - it's good enough to know that the chosen
separator will not appear in just the strings to be returned), then I
vote for a command line option to change the separator because it's
simple and easy to parse.
Quoted strings would be a pain from a scripting point of view because
parsing becomes more difficult.  One can't just split the "input" on
some delimiter.
Lewis
caget with an array of space-containing strings Carl Schumann
Re: caget with an array of space-containing strings J. Lewis Muir
Re: caget with an array of space-containing strings Ralph Lange
Prev: Re: Record Initialization Dirk Zimoch
Next: Re: caget with an array of space-containing strings Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: caget with an array of space-containing strings Ralph Lange
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
