Hi Carl,
if your string holds any kind of valuable information, it might be best
to break it down as soon as you get in your ioc - other processes will
make sense of it without having to re-parse the information, including
caget.
xml enthusiasts please destroy my argument but I found strings more like
a convenient SMS.
Looking at your output, if you're debugging something lower level
consider a regexp (scripted, or awk if you want command line) will
probably do the job.
Matthieu
Carl Schumann wrote:
I am using the command-line caget with an array of space-containing
strings. Apparently caget uses spaces to separate array elements. A
space separator causes some difficultly in this case because the
elements themselves contains spaces. For example, ...
clx39:~ $ caget -# 1 ADC00.RNGS
ADC00.RNGS 50, 10k: -10->0
clx39:~ $ caget ADC00.RNGS
ADC00.RNGS 9 50, 10k: -10->0 50, 10k: +-5 50, 10k: 0->10 50: -6->0,
10k: -5->0 50: +-3, 10k: +-2.5 50, 10k: 0->5 50: -5->0, 10k: -2->0 50:
+-2.5, 10k: +-1 50: 0->5, 10k: 0->2
clx39:~ $
One can ask for specific elements as I have done, but that is a little
bit inconvenient. Any suggestions?
Carl Schumann
Matthieu Bec Gemini Observatory
Tel: +56 51 205785 c/o AURA, Casilla 603
Fax: +56 51 205650 La Serena, Chile
- caget with an array of space-containing strings Carl Schumann
Re: caget with an array of space-containing strings Ralph Lange
Record Initialization Szalata, Zenon M.
<2009>
Re: caget with an array of space-containing strings Andrew Johnson
Re: caget with an array of space-containing strings Dirk Zimoch
<2009>
ANJ, 31 Jan 2014 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
