1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: can't output strings array with gensub
To: haquin <[email protected]>
Cc: tech-talk Techtalk <[email protected]>
Date: Tue, 24 Feb 2009 08:03:57 -0600
Are you trying to just send and print the concatenated error message strings?
Perhaps something like this is adequate?
	FTVN: CHAR
	NOVN: 120
	int nleft = precord->novn;
	char *np = (char *)precord-:>valn;
	int n;
	n = epicsSnprintf(np, nleft, "Defect string 1. ");
	nleft -= n;
	np += n;
	n = epicsSnprintf(np, nleft, "Defect string 2.  ");
	nleft -= n;
	np += n;
haquin wrote:
Hi all,
I have configured a gensub record to output a string array but this doesn't work.
I set the following genSub fields:
FTVN:STRING
NOVN:12
in my process function I do the following:
 sprintf ((char*)precord->valn, "Defect String 1");
 sprintf ( (char*)(((char**)(precord->valn))+1), "Defect String 2");
When I execute the IOC, the output is the following:
epics> dbgf IOCASTE-TST:ProcessDynamicModbusTable.VALN
DBR_STRING:          DefeDefect String 2
the second string has overwritten the first one.
It seems that there only one string
thanks in advance for your help.
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
Re: can't output strings array with gensub haquin
Re: can't output strings array with gensub Matthieu Bec
Prev: Re: soft device for ai record works as sscanf. Noboru Yamamoto
Next: Re: can't output strings array with gensub haquin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: can't output strings array with gensub Matthieu Bec
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
