1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Basic record question (fanout / mbbo /longout)
To: "Emmanuel Mayssat" <[email protected]>, "epics" <[email protected]>
Date: Mon, 23 Feb 2009 21:19:57 -0600
Emmanuel,
1/ Are you talking about the LNK1, LNK2, etc. fields or the FLNK field?  Your error mssage indicates the FLNK field.  In any case it should work with CA_LINKs, but as the message said you need to explicitly reference the .PROC field, not the .VAL field (which is the default).
2/ You want to write the RVAL field rather than the VAL field, so you want to select DTYP="Raw Soft Channel", not the default which is "Soft Channel".  This is explained in the Record Reference Manual.
3/ The text entry widget in medm definitely works fine with a longout record, I use it all the time.  What problem are you having?
From: [email protected] on behalf of Emmanuel Mayssat
Sent: Mon 2/23/2009 6:56 PM
To: epics
Subject: Basic record question (fanout / mbbo /longout)
Hello all,
1/
Is it possible to have a fanout that link to a record that is a CA_LINK
instead of a DB_LINK. For some reason, for me it doesn't work.
Reported error is
ZT4612:2:AChnlFO.FLNK is a Channel Access Link  but does not access
field PROC
2/
Also I would like a mbbo to directly output (no other record) on a AO
record.
For example, 5/10/79/83 are mbbo options and values admissible by the
AO. When the MBBO is pressed, the value is propagated to the AO.
So far I have only been able to propagate a value from 0 to 15
(Mbbo.val)
Aren't ZRVL .. FTVL used for that purpose? Apparently no.
3/
With MEDM, is there a way to set longout records?
I have noticed that the "text entry" widget is not compatible with it.
Any help is appreciated!
Emmanuel
Basic record question (fanout / mbbo /longout) Emmanuel Mayssat
Prev: Re: Add vxstats to an application Mi Qingru
Next: soft device for ai record works as sscanf. Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Basic record question (fanout / mbbo /longout) Emmanuel Mayssat
Next: Re: Basic record question (fanout / mbbo /longout) Benjamin Franksen
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
