1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Asyn driver access to PV fields.
Cc: [email protected]
Date: Fri, 20 Feb 2009 08:31:43 -0600
Mark,
However, there may be a quick solution to Brian's problem, since I suspect it is related to areaDetector?
It is related to AD and this "trick" is where I got burned to begin with :) In my case (Perkin Elmer), I have an areaDetector device driver that talks to a family of detectors: a 1 megapixel and a 4 megapixel panel in this case. The vendor API is the same for each. I naively set the mbbo for the detector timings to the values for the 1 megapixel detector I've been developing with by setting the values in the detector template file as you suggest. When we started using the 4 megapizel panel, the frame rates were all wrong because it uses different timings.
I can create a different template file for each panel but the valid timing values can be retrieved from the detector at run time. It would be better to be able to set them somehow.
It looks like these panels may support a more arbitrary selection of exposure timings and that the 8 preset timings provided by the vendor API are more of a convenience. If this turns out to be true, I'll drop the mbbo and use a more generic record type for this case, but I know of other detectors where this may be an issue as well.
Brian
Asyn driver access to PV fields. tieman
RE: Asyn driver access to PV fields. Mark Rivers
Re: Asyn driver access to PV fields. Marty Kraimer
Prev: RE: Asyn driver access to PV fields. Mark Rivers
Next: Mac OS X and environ Stephen Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Asyn driver access to PV fields. Dirk Zimoch
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
