On 2/13/09 4:46 PM, Dropp, Christopher wrote:
> Greetings,
> I get the following error when trying to compile medm 3.1.3 on fedora
> 10:
> ../utils.c: In function ‘parseAndExecCommand’:
> ../utils.c:4288: warning: the address of ‘command’ will always
> evaluate as ‘true’
> ../utils.c:4763:2: error: #error getEventType only works for
> LASTEvent=35 (See X.h)
> Then it exits with 9 make statements. Has anyone seen this or tried
> using medm 3.1.3 on f10?
Hi, Chris.
I've seen something similar on Mac OS X.
When building MEDM 3.1.3, it failed for me with the following error:
/usr/bin/cc -c -DUNIX -Ddarwin -ansi -O3 -g -Wall
-DSCIPLOT -DMOTIF -DEDITRES -fno-common -I. -I../O.Common -I.
-I.. -I../../../../include/os/Darwin -I../../../../include
-I../../../../../base/include/os/Darwin -I../../../../../base/include
-I../../../../include -I../../printUtils -I../../xc -I/opt3/include
-I/usr/X11R6/include/X11 -I/opt3/include ../utils.c
make[4]: *** [utils.o] Error 1
make[3]: *** [install.darwin-x86] Error 2
make[2]: *** [medm.install] Error 2
make[1]: *** [medm.install] Error 2
make: *** [src.install] Error 2
Upon investigation, this appears to be because my X.h supports the X
Generic Event extension (XGE) <http://www.x.org/wiki/Development/
Documentation/XGE>. If it's helpful, here's a commit against an
xorg/proto/x11proto Git tree showing the change to X.h:
http://cgit.freedesktop.org/xorg/proto/x11proto/commit/
?id=44e458285bb2e7771963a9ab9b5f03d2fb48e611
With XGE, a new event opcode has been added, GenericEvent=35, and
LASTEvent became 36 instead of 35. Attached is a patch against MEDM
3.1.3 that will make it work if LASTEvent is 35 or 36.
I sent this patch to Ken Evans and Janet Anderson on January 7, 2009,
but have not heard a response from either. Are they still maintaining
MEDM or should I have sent it to someone else?
Lewis
J. Lewis Muir
Software Engineer
IMCA-CAT/CARS
--- medm/utils.c.orig 2008-11-18 12:52:32.000000000 -0500
+++ medm/utils.c 2009-01-07 19:23:48.000000000 -0500
@@ -4759,8 +4759,8 @@
char *getEventName(int type)
-#if LASTEvent != 35
-#error getEventType only works for LASTEvent=35 (See X.h)
+#if LASTEvent != 35 && LASTEvent != 36
+#error getEventType only works for LASTEvent=35 or LASTEvent=36 (See X.h)
#endif
/* These types are from X11/X.h */
static char *eventNames[LASTEvent+2]={
@@ -4799,6 +4799,9 @@
"ColormapNotify",
"ClientMessage",
"MappingNotify",
+#if LASTEvent == 36
+ "GenericEvent",
+#endif
"LASTEvent",
"Unknown"
- Re: compile error with medm 3.1.3 on fedora 10 Andrew Johnson
- compile error with medm 3.1.3 on fedora 10 Dropp, Christopher
<2009>
RE: compile error with medm 3.1.3 on fedora 10 Dropp, Christopher
<2009>
