1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: compile error with medm 3.1.3 on fedora 10
To: [email protected]
Date: Fri, 13 Feb 2009 16:02:18 -0600
Hi Chris,
On Friday 13 February 2009 15:46:02 Dropp, Christopher wrote:
> I get the following error when trying to compile medm 3.1.3 on fedora 10:
> ../utils.c: In function ?parseAndExecCommand?:
> ../utils.c:4288: warning: the address of ?command? will always evaluate as
> ?true? ../utils.c:4763:2: error: #error getEventType only works for
> LASTEvent=35 (See X.h)
> Then it exits with 9 make statements. Has anyone seen this or tried using
> medm 3.1.3 on f10?
Yes, the X.org guys added a new event type, for the first time since almost
never.  Apply the attached patch to the medm/utils.c file to get something
that builds on both old and new versions of X11.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
Index: utils.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/extensions/src/medm/medm/utils.c,v
retrieving revision 1.134
retrieving revision 1.135
diff -d -u -b -B -p -r1.134 -r1.135
--- utils.c	18 Nov 2008 17:52:32 -0000	1.134
+++ utils.c	4 Feb 2009 18:11:41 -0000	1.135
@@ -4759,8 +4759,8 @@ void printWindowAttributes(Display *disp
 char *getEventName(int type)
-#if LASTEvent != 35
-#error getEventType only works for LASTEvent=35 (See X.h)
+#if ((LASTEvent < 35) || (LASTEvent > 36))
+#error getEventType only works for LASTEvent=35 or 36 (See X.h)
 #endif
   /* These types are from X11/X.h */
     static char *eventNames[LASTEvent+2]={
@@ -4799,6 +4799,9 @@ char *getEventName(int type)
 	"ColormapNotify",
 	"ClientMessage",
 	"MappingNotify",
+#if (LASTEvent == 36)
+	"GenericEvent",
+#endif
 	"LASTEvent",
 	"Unknown"
RE: compile error with medm 3.1.3 on fedora 10 Dropp, Christopher
Prev: RE: compile error with medm 3.1.3 on fedora 10 Mark Rivers
Next: Re: compile error with medm 3.1.3 on fedora 10 J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: compile error with medm 3.1.3 on fedora 10 Dropp, Christopher
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
