1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: compile error with medm 3.1.3 on fedora 10
To: "Dropp, Christopher" <[email protected]>, <[email protected]>
Date: Fri, 13 Feb 2009 15:56:39 -0600
Yes, I saw it last week and Andrew Johnson came up with a patch which
works:
Here it is:
Index: medm/utils.c
RCS file:
/net/phoebus/epicsmgr/cvsroot/epics/extensions/src/medm/medm/utils.c,v
retrieving revision 1.134
diff -d -u -b -B -p -r1.134 utils.c
--- medm/utils.c	18 Nov 2008 17:52:32 -0000	1.134
+++ medm/utils.c	4 Feb 2009 16:58:35 -0000
@@ -4759,8 +4759,8 @@ void printWindowAttributes(Display *disp
 char *getEventName(int type)
-#if LASTEvent != 35
-#error getEventType only works for LASTEvent=35 (See X.h)
+#if ((LASTEvent < 35) || (LASTEvent > 36))
+#error getEventType only works for LASTEvent=35 or 36 (See X.h)
 #endif
   /* These types are from X11/X.h */
     static char *eventNames[LASTEvent+2]={
@@ -4799,6 +4799,9 @@ char *getEventName(int type)
 	"ColormapNotify",
 	"ClientMessage",
 	"MappingNotify",
+#if (LASTEvent == 36)
+	"GenericEvent",
+#endif
 	"LASTEvent",
 	"Unknown"
-----Original Message-----
[mailto:[email protected]] On Behalf Of Dropp, Christopher
Sent: Friday, February 13, 2009 3:46 PM
To: [email protected]
Subject: compile error with medm 3.1.3 on fedora 10
Greetings,
I get the following error when trying to compile medm 3.1.3 on fedora
10:
../utils.c: In function 'parseAndExecCommand':
../utils.c:4288: warning: the address of 'command' will always evaluate
as 'true'
../utils.c:4763:2: error: #error getEventType only works for
Then it exits with 9 make statements. Has anyone seen this or tried
using medm 3.1.3 on f10?
Thanks in advance!!
Chris
Christopher Dropp
Biology Department
Brookhaven National Laboratory
Upton, NY 11973
Phone: 631-344-3421
Pager: 631-344-3456 pgr #: 7408
Fax: 631-344-2741
E-Mail: [email protected]
compile error with medm 3.1.3 on fedora 10 Dropp, Christopher
Prev: compile error with medm 3.1.3 on fedora 10 Dropp, Christopher
Next: Re: compile error with medm 3.1.3 on fedora 10 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
