Vanilla 3.14.10 still doesn't initialize the time-related
variables correctly when run-time loading an EPICS application.
The attached patch below should fix this.
HTH
-- Till
Index: src/libCom/osi/os/RTEMS/osdTime.cpp
RCS file: /afs/slac/g/lcls/cvs/epics/base/3.14.10/src/libCom/osi/os/RTEMS/osdTime.cpp,v
retrieving revision 1.1.1.1
diff -c -r1.1.1.1 osdTime.cpp
*** src/libCom/osi/os/RTEMS/osdTime.cpp 11 Jan 2009 02:33:42 -0000 1.1.1.1
--- src/libCom/osi/os/RTEMS/osdTime.cpp 6 Feb 2009 23:35:37 -0000
*** 27,32 ****
--- 27,33 ----
extern rtems_interval rtemsTicksPerSecond;
int rtems_bsdnet_get_ntp(int, int(*)(), struct timespec *);
+ extern int rtems_bsdnet_ticks_per_second;
static int ntpSocket = -1;
void osdTimeRegister(void)
*** 116,132 ****
* explicitly calls osdTimeRegister() at the appropriate time.
* However if we are loaded dynamically we *do* register our
* standard time providers at static constructor time; in this
! * case the tick rate will have been set already.
static int staticTimeRegister(void)
- if (rtemsTicksPerSecond != 0)
- osdTimeRegister();
rtems_clock_get (RTEMS_CLOCK_GET_TICKS_PER_SECOND, &rtemsTicksPerSecond);
rtemsTicksPerSecond_double = rtemsTicksPerSecond;
rtemsTicksPerTwoSeconds_double = rtemsTicksPerSecond_double * 2.0;
return 1;
static int done = staticTimeRegister();
--- 117,133 ----
! * case the bsdnet tick rate will have been set already.
+ if (rtems_bsdnet_ticks_per_second != 0)
+ osdTimeRegister();
return 1;
Re: Diamond Libera EPICS Driver Michael Abbott
EDM 1-11-1zc problems Szalata, Zenon M.
<2009>
"Count Num or Channel" option in MEDM cartesian plot Noboru Yamamoto
<2009>
