Hm.
Seen from the client machine you will need outgoing access to 5064/TCP
(data connection), 5064/UDP outgoing and incoming (name resolution), and
5065/UDP incoming (server beacons).
Timeouts are usually caused by the name resolution mechanism not working
properly. Can you run wireshark to see if the outgoing name requests
and/or the incoming answers are blocked?
Good luck!
Ralph
On 05.02.2009 22:15 Chris Jacobsen wrote:
Hi - I'd like to have a firewall configured on my linux system but
when I turn it on then I get a timeout when accessing EPICS variables
on a remote system. I thought it would be sufficient to enable TCP
and UDP access on ports 5064 and 5065, since I'm running with a
"standard" EPICS build on the latest release. Can anyone suggest what
else I need to set in a firewall configuration to allow EPICS to work?
Thanks, Chris Jacobsen
- Firewall configuration? Chris Jacobsen
RE: Firewall configuration? Mark Rivers
<2009>
<2009>
ANJ, 31 Jan 2014 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
