We encountered same problem when we building KEKB control system.
Our solution is to modify EPICS base and provide API to access a part of
source waveform. And also we created a record named
CompactSubArrayRecord, which uses API above and copy data just it needs.
Unfortunately this mechanism works only for DB-link but not for CA-link.
(We will need to extend CA protocol to access a part of waveform
data,say channel name like "myWaveFormRecord[10:20]")
And also you need to change source code of base.
We have been using this version of modified base in KEKB and J-PARC and
encounters no problem caused by this change.
Noboru Yamamoto
J-PARC control group/J-PARC center(KEK & JAEA)
EPICS group/KEK
JAPAN
Thomas Birke wrote:
Thomas Birke wrote:
Since the INDX actually has nothing to do with the subArray-record
itself, but is just an index into the referenced waveform (of unknown
size), to me it makes no sense at all to limit INDX to MALM-1.
For me the only solution is to set MALM of my subArray to INDX+NELM
which leads to hundreds of oversized and allocated arrays in my
subArray-records.
E.g. to slice out the last element of a waveform, I have to
(statically!) allocate space for the whole source-waveform and then
copy exactly one element.
I simply ask to drop these 4 lines of code from subArrayRecord.c - it
shouldn't even break existing installations, and for my case I could
reduce memory-consumption a lot.
Ooops - I just found, that this has been discussed before (back in 2005,
see http://www.aps.anl.gov/epics/tech-talk/2005/msg00924.php).
I should have looked at the tech-talk archives before, sorry...
The problem is, that you actually can't index into the source-waveform.
Values retrieved always range from index 0 to <n>.
Maybe we should at least point out this behaviour in the Record
Reference Manual. It's not only NELM that must not be greater that MALM,
but also INDX+NELM always must be less or equal MALM, otherwise NORD
will be less then NELM.
Thomas
- Re: Problem with subArray - unnecessary memory allocation Thomas Birke
- Problem with subArray - unnecessary memory allocation Thomas Birke
<2009>
<2009>
