1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem with subArray - unnecessary memory allocation
To: [email protected]
Date: Wed, 04 Feb 2009 12:32:22 +0100
Thomas Birke wrote:
Since the INDX actually has nothing to do with the subArray-record itself, but is just an index into the referenced waveform (of unknown size), to me it makes no sense at all to limit INDX to MALM-1.
For me the only solution is to set MALM of my subArray to INDX+NELM which leads to hundreds of oversized and allocated arrays in my subArray-records. E.g. to slice out the last element of a waveform, I have to (statically!) allocate space for the whole source-waveform and then copy exactly one element.
I simply ask to drop these 4 lines of code from subArrayRecord.c - it shouldn't even break existing installations, and for my case I could reduce memory-consumption a lot.
Ooops - I just found, that this has been discussed before (back in 2005, see http://www.aps.anl.gov/epics/tech-talk/2005/msg00924.php).
I should have looked at the tech-talk archives before, sorry...
The problem is, that you actually can't index into the source-waveform. Values retrieved always range from index 0 to <n>.
Maybe we should at least point out this behaviour in the Record Reference Manual. It's not only NELM that must not be greater that MALM, but also INDX+NELM always must be less or equal MALM, otherwise NORD will be less then NELM.
Thomas
Thomas Birke
Operation Controls
Elektronenspeicherring BESSY II
Albert-Einstein-Str. 15, 12489 Berlin
Fon +49 30 6392 4934
Fax +49 30 6392 4859
Helmholtz-Zentrum Berlin für Materialien und Energie GmbH Glienicker Straße 100, 14109 Berlin Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph Stellvertretende Vorsitzende: Dr. Jutta Koch-Unterseher Geschäftsführer: Prof. Dr. Anke Rita Pyzalla, Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Dr. Ulrich Breuer Sitz der Gesellschaft: Berlin Handelsregister: AG Charlottenburg, 89 HRB 5583 Information: Durch die Fusion mit dem ehemaligen Hahn-Meitner-Institut (HMI) ist BESSY nun Teil des neuen Helmholtz-Zentrum Berlin für Materialien und Energie (HZB). By the merger with the former Hahn-Meitner-Institut (HMI), BESSY became part of the new Helmholtz-Zentrum Berlin für Materialien und Energie (HZB). Disclaimer automatically attached by the E-Mail Security Appliance mail0.bessy.de 02/04/09 at Helmholtz-Zentrum Berlin GmbH.
Re: Problem with subArray - unnecessary memory allocation Noboru Yamamoto
Problem with subArray - unnecessary memory allocation Thomas Birke
Prev: Problem with subArray - unnecessary memory allocation Thomas Birke
Next: Re: Problem with subArray - unnecessary memory allocation Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
