1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Changes to PCAS in 3.14
To: [email protected]
Date: Tue, 03 Feb 2009 16:01:33 -0500
I just discovered my old programs that use the PCAS library (3.13) no longer work with the latest release (3.14.10), and I haven't a clue why. Is there a document somewhere explaining what has changed?
Below are debug output and errors I get when I run the server and execute "caget halld_event_count" in another window. The server creates and serves out a PV named halld_event_count.
Output from server:
(caget run in another window at this point, see below for caget output)
pvExistTest for halld_event_count
createPV for halld_event_count
myPV::createChannel for halld_event_count
myPV::read for halld_event_count
...myPV getVAL for halld_event_count
----------dump This=0x81497b8---------
dimension=0 app-type=16 Scalar
prim-type=aitInvalid(aitEnumInvalid) ref-count=1
total-bytes=44, data-size=0, element-count=1
LocalDataFormat
filename="../../../../src/cas/generic/casStrmClient.cc" line number=620
server tool changed bounds on request - get notify with PV=halld_event_count type=19 count=1
...myPV interestDelete for halld_event_count
myPV destroy for halld_event_count
caget errors:
$ caget halld_event_count
CA.Client.Exception...............................................
   Warning: "No reasonable data conversion between client and server types"
Context: "op=0, channel=halld_event_count, type=DBR_TIME_LONG, count=1, ctx="read failed""
   Source File: ../getCopy.cpp line 86
   Current Time: Tue Feb 03 2009 15:56:19.360220762
Read operation timed out: some PV data was not read.
halld_event_count              0
				Sincerely,
					Elliott
Those raised in a morally relative or neutral environment will hold
		    no truths to be self-evident.
Elliott Wolin
Staff Physicist, Jefferson Lab
12000 Jefferson Ave
Suite 8 MS 12A1
Newport News, VA 23606
757-269-7365
RE: Changes to PCAS in 3.14 Jeff Hill
Prev: Re: SNCSEQ Path Problem Tim Mooney
Next: RE: Changes to PCAS in 3.14 Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Multiple power supplies on one IOC Bertrand H.J. Biritz
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
