Hi Andrew
Thanks, that works around the problem nicely.
Steve
----- Original Message -----
To: <[email protected]>
Cc: "Steve Kinder" <[email protected]>
Sent: Thursday, January 22, 2009 8:51 PM
Subject: Re: vdct problem with quoted strings
Hi Steve,
On Thursday 22 January 2009 14:27:44 Steve Kinder wrote:
I have seen what may be a bug with vdct when using quoted strings in
fields. This has occured when using these strings in the calc fields of
scalcout records. As an example using calcs like A=6?0:dbl(AA["X ","Z"]).
vdct saves this as field(CALC, "A=6?0:dbl(AA[\"X \",\"Z\"])"). Fine.
However when running vdct again and loading these fields back in they all
seem to be truncated after the first \.
Not sure there will be an easy workaround this. I believe the quotes
within
the field are necessary. Just wanted to report it somewhere as it seems
like a bug.
It looks like the scalcout record understands both single- and
double-quoted
strings, so try using this for your expression instead:
A=6?0:dbl(AA['X ','Z'])
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
- vdct problem with quoted strings Steve Kinder
- Re: vdct problem with quoted strings Andrew Johnson
Re: RTEMS soft reboot Till Straumann
Re: stop all motors Kate Feng
<2009>
RTEMS soft reboot Matt Rippa
<2009>
