On 1/22/09 6:20 PM, Richard Pastrick wrote:
> I have run into that before but that is not the problem. I have the
> mouse hovering over the text field in question and nothing is entered.
> I was reading up on a previous thread on tech talk where my exact
> problem was reported but the fix does not help my situation.
> http://www.aps.anl.gov/epics/tech-talk/2007/msg01116.php
> I also did a search to see if the issue was related specifically to
> cygwin and it appears to be so. I believe it has to do with the
> environment variable XKEYSYMDB. If it is set, I cannot use xterm or
> medm.
> Anyone have any other thoughts? This is a fresh install of cygwin and
> I copied the XKeySymDB file from this cygwin install to the epics dir
> and pointed the environment variable at that.
> Thanks.
> -Richard
Hi, Richard.
Do you get any error messages? Do you have a .xsession-errors file in
your home directory with anything relevant in it?
Another possibility might be to try Xming to see if that makes a
difference:
http://www.straightrunning.com/XmingNotes/
Lewis
- RE: MEDM EPICS Win32 Extensions Richard Pastrick
- MEDM EPICS Win32 Extensions Richard Pastrick
- Re: MEDM EPICS Win32 Extensions Paul Sichta
<2009>
<2009>
