THe fanout record was created in part to help limit the stack size used.
So each FLNK followed is a recursive call to record processing (pushes the context on the stack)
When you use a fanout record, then each path you follow with it's subsequent FLNK's use the stack this way - but before you follow the next FLNK fo the fanout record - you have cleared the stack of every context from the previous FLNK.
Bob
-----Original Message-----
Sent: Thu 1/22/2009 10:52 AM
To: Kate Feng
Cc: tech-talk Techtalk
Subject: Re: RTEMS stack sizes
Would it make sense to provide an environment variable
(EPICS_THREAD_STACK_SIZE_MULTIPLIER?) or several such variables
(EPICS_THREAD_STACK_SIZE_SMALL, _MEDIUM, _LARGE) to allow the default
values to be overridden?
On Jan 22, 2009, at 9:48 AM, Kate Feng wrote:
> Eric Norum wrote:
>> Right -- a huge FLNK chain will eat up lots of stack. We found
>> this when we tried to FLNK 128 records....
>> I'm trying to find a size that's "good enough" for reasonable
>> cases. The current RTEMS sizes are about the same as those of
>> vXWorks non-68k architecture machines and about twice that of
>> vxWorks 68k machines.
> It is a good idea to find a size that's "good enough" for default.
> It would be nice
> that those size could be custom defined at the
> configure/os/CONFIG.Common.RTEMS-bsp for various needs of
> applications.
> Kate
>> On Jan 22, 2009, at 9:23 AM, Jeff Hill wrote:
>>> Note that the CAS-client thread calls db_put_field, and as I
>>> recall the
>>> stack usage by db_put_field is dependent on the longest chain of
>>> records
>>> that might be manipulated in the database (due to the recursive
>>> implementation of the database).
>>>> From: [email protected] [mailto:[email protected]
>>>> On Behalf Of Eric Norum
>>>> Sent: Wednesday, January 21, 2009 8:01 PM
>>>> To: tech-talk Techtalk
>>>> Subject: RTEMS stack sizes
>>>> I'd like to solicit information from the EPICS community on the
>>>> stack
>>>> allocation for RTEMS IOCs. Please check the stack usage of some of
>>>> your RTEMS IOCs and send me the results. I would like to find
>>>> out if
>>>> it is possible and desirable to reduce the stack sizes to reduce
>>>> the
>>>> memory footprint for each client.
>>>> Here's the stack usage for one of the IOCs here (a ColdFire uCDIMM
>>>> 5282):
>>>> PID PRI STATE %CPU %STK NAME
>>>> 09010001 255 READY 35.8 0 IDLE
>>>> 0a01004c 180 READY 10.6 18 CAS-event
>>>> 0a01001c 134 Wmutex 9.7 23 scan0.2
>>>> 0a010004 10 Wevnt 6.0 19 ntwk
>>>> 0a010006 10 Wevnt 6.0 22 FECr
>>>> 0a01005b 180 READY 4.2 18 CAS-event
>>>> 0a010044 180 READY 3.5 19 CAS-event
>>>> 0a010071 180 READY 3.5 19 CAS-event
>>>> 0a010005 10 Wevnt 3.2 22 FECt
>>>> 0a010031 179 READY 3.1 19 save_restore
>>>> 0a010020 183 READY 3.0 22 CAS-UDP
>>>> 0a01001a 136 Wmutex 2.2 23 scan1
>>>> 0a010019 137 Wmutex 1.5 23 scan2
>>>> 0a01003f 180 READY 1.3 16 CAS-event
>>>> 0a010021 180 READY 1.2 18 CAS-event
>>>> 0a010007 10 Wevnt 0.9 22 RPCd
>>>> 0a01002e 179 READY 0.7 20 CAS-client
>>>> 0a01006a 179 READY 0.7 20 CAS-client
>>>> 0a01002c 179 Wevnt 0.4 20 CAS-client
>>>> 0a010048 179 Wevnt 0.3 20 CAS-client
>>>> 0a010018 138 Wmutex 0.3 23 scan5
>>>> 0a010042 179 Wevnt 0.3 20 CAS-client
>>>> 0a01004e 179 Wevnt 0.1 20 CAS-client
>>>> 0a01001d 133 Wmutex 0.1 24 scan0.1
>>>> 0a010053 180 READY 0.0 19 CAS-event
>>>> 0a01000d 149 Wmutex 0.0 20 L0
>>>> 0a01001b 135 Wmutex 0.0 24 scan0.5
>>>> 0a010011 129 Wmutex 0.0 23 timerQueue
>>>> 0a010073 180 READY 0.0 19 CAS-event
>>>> 0a01002b 179 Wevnt 0.0 20 CAS-client
>>>> 0a010012 140 Wmutex 0.0 23 cbLow
>>>> 0a010017 139 Wmutex 0.0 20 scan10
>>>> 0a01005c 108 READY 0.0 16 SPY
>>>> 0a01000e 109 Wevnt 0.0 17 timeBroadcastMonitor
>>>> 0a010027 148 DELAY 0.0 23 seqAux
>>>> 0a010067 180 Wmutex 0.0 24 CAS-event
>>>> 0a010065 180 Wmutex 0.0 24 CAS-event
>>>> 0a010066 179 Wevnt 0.0 23 CAS-client
>>>> 0a01005f 180 Wmutex 0.0 19 CAS-event
>>>> 0a010062 179 Wevnt 0.0 20 CAS-client
>>>> 0a010078 179 Wevnt 0.0 23 CAS-client
>>>> 0a010076 179 Wevnt 0.0 23 CAS-client
>>>> 0a010074 179 Wevnt 0.0 20 CAS-client
>>>> 0a01006d 180 Wmutex 0.0 19 CAS-event
>>>> 0a010057 180 Wmutex 0.0 24 CAS-event
>>>> 0a010043 179 Wevnt 0.0 23 CAS-client
>>>> 0a01004b 179 Wevnt 0.0 20 CAS-client
>>>> 0a010054 179 Wevnt 0.0 20 CAS-client
>>>> 0a010052 179 Wevnt 0.0 23 CAS-client
>>>> 0a010051 180 Wmutex 0.0 19 CAS-event
>>>> As you can see, no thread is using more then one quarter of its
>>>> allocated stack space.
>>>> The current stack allocations are:
>>>> epicsThreadStackSmall: stackSize = 8000
>>>> epicsThreadStackMedium: stackSize = 12000
>>>> epicsThreadStackBig: stackSize = 16000
>>>> Perhaps these could be reduced by 30 to 50 percent???
>>>> Each client results in the allocation of a 'Big' stack for the CAS-
>>>> client thread and a 'Medium' stack for the CAS-event thread.
>>>> Eric Norum <[email protected]>
>>>> Advanced Photon Source
>>>> Argonne National Laboratory
>>>> (630) 252-4793
>> --Eric Norum <[email protected]>
>> (630) 252-4793
(630) 252-4793
- RTEMS stack sizes Eric Norum
- Re: RTEMS stack sizes Eric Norum
- Re: RTEMS stack sizes Kate Feng
<2009>
<2009>
