2) There is a more subtle ongoing problem that (as far as I know) has
only been reported here at Jefferson Lab. When an EDM session has been
left running for a long (variable) time, the widgets will stop
updating despite the fact that the PV values are still changing. There
is no visual clue that anything is wrong, unless you can see the same
PV's in a different app or a separate EDM session. Usually everything
will start updating again if you open or close a display, or even
expose a covered display. This issue only started when we moved from
HP-UX to RedHat Enterprise Linux. It has not yet been resolved.
It would be interesting to know more about this. If you mouse over
a display element like a text control and do a control-middle-mouse
click you will get something like the following in the message window.
Text Control (105,46): b:Vgc12-1Ig1:PressureR
Host: orib60.phy.ornl.gov:5064
Num times conected = 1
Num times disconected = 0
Num value changes = 1
Num references = 2
Time stamp = Wed Jan 21 17:11:00 2009
It would be nice to know if the various pvs that were no longer updating
had any things in common like hostname, timestamp, or if any of the
numeric values looked fishy (negative values, etc.).
John Sinclair
- Re: EDM freezes Brian Bevins
- EDM freezes Szalata, Zenon M.
- Re: EDM freezes John Dobbins
- RE: EDM freezes Szalata, Zenon M.
RE: Multithreading in R3.14.9 - preemptive callbacks not working. Douglas Morrison
Re: EDM freezes Dave Reid
<2009>
<2009>
