Hi Mauro
Although I have not much of a chance to play with the M340
series CPU I have looked at the configuration of them in UnityPro and see no reason
that the configuration Mark described here (that is used on a Schneider Premium
CPU) will not work on the M340.
I’m happy to help with the PLC end if you need any
Regards
Bryce Karnaghan | Controls Specialist | Australian Synchrotron
p: (03)
8540 4135 | f: (03) 8540 4200 | m: 0423 844 592
[email protected] |
www.synchrotron.org.au
800 Blackburn Road, Clayton, Victoria 3168
Hi Mauro,
The Koyo PLCs support reading the X inputs and Y outputs
directly over Modbus.
The Modicon PLCs do not support this, they can only read
the M or MW memory locations over Modbus. Thus, you will need to modify
your ladder logic to copy the inputs and outputs you need to M or MW locations
(note that you may already be doing this for other purposes).
Here is an example script I run for a Modicon PLC.
I am using the MW locations to read 16-bit analog values and logic bits grouped
into 16-bit words.
I am using the M locations as outputs to write bits from
EPICS to the PLC. These are used to request that the PLC perform certain
actions if it is safe to do so.
# Modicon PLC
drvAsynIPPortConfigure("Modicon","10.114.2.71:502",0,1,1)
modbusInterposeConfig("Modicon",0,0)
# Read locations %MW0 to %MW16 as
words. Function code=3.
drvModbusAsynConfigure("M1_W000_In",
"Modicon", 3, 0, 16,
0, 100, "Modicon")
# Read locations %MW100 to %MW199 as words.
Function code=3.
drvModbusAsynConfigure("M1_W100_In",
"Modicon", 3, 100, 100, 0, 100,
"Modicon")
# Write locations %MW100 to %MW199 as words.
Function code=6.
drvModbusAsynConfigure("M1_W100_Out",
"Modicon", 6, 100, 100,
0, 1, "Modicon")
# Read locations %MW200 to %MW299 as words.
Function code=3.
drvModbusAsynConfigure("M1_W200_In",
"Modicon", 3, 200, 100, 0, 100,
"Modicon")
# Read locations %MW300 to %MW399 as words.
Function code=3.
drvModbusAsynConfigure("M1_W300_In",
"Modicon", 3, 300, 100, 0, 100,
"Modicon")
# Write locations %MW300 to %MW399 as words.
Function code=6.
drvModbusAsynConfigure("M1_W300_Out",
"Modicon", 6, 300, 100,
0, 1, "Modicon")
# Access 32 bits %M128 to %M160 as outputs.
Function code=5.
drvModbusAsynConfigure("M1_B128_Out",
"Modicon", 5, 128, 16,
0, 1, "Modicon")
# Hex trace format on TCP server
asynSetTraceIOMask("Modicon",0,4)
# Turn on asynError and asynTraceIODriver on TCP server
#asynSetTraceMask("Modicon",0,9)
dbLoadTemplate
"$(TOP)/db/Modicon.substitutions"
This is a part of the contents of Modicon.substitutions,
the EPICS database:
# asyn record for the underlying asyn TCP port
file "$(ASYN)/db/asynRecord.db" { pattern
{P,
R,
PORT, ADDR, IMAX,
OMAX}
{SR05ID01PLC01:
ASYN_REC,
Modicon, 0,
80, 80}
# These are the Mn inputs done with word access (%MW0 -
%MW15)
file "$(MODBUS)/db/bi_word.template" { pattern
{P,
R,
PORT, OFFSET,
MASK,
ZNAM,
ONAM, ZSV,
OSV, SCAN}
{SR05ID01CCG01:,
PRESS_STATUS,
M1_W000_In, 0,
0x0001,
OK, Fault,
NO_ALARM, MAJOR, "I/O Intr"}
{SR05ID01CCG01:,
PRESS_LATCH_STATUS,
M1_W000_In, 1,
0x0001,
OK, Fault,
{SR05ID01CCG02:,
PRESS_STATUS,
M1_W000_In, 0,
0x0002,
OK, Fault,
{SR05ID01CCG02:,
PRESS_LATCH_STATUS,
M1_W000_In, 1,
0x0002,
OK, Fault,
{SR05ID01CCG03:,
PRESS_STATUS,
M1_W000_In, 0,
0x0004,
OK, Fault,
{SR05ID01CCG03:,
PRESS_LATCH_STATUS,
M1_W000_In, 1,
0x0004,
OK, Fault,
{SR05ID01CCG04:, PRESS_STATUS,
M1_W000_In,
0,
0x0008,
OK, Fault,
{SR05ID01CCG04:,
PRESS_LATCH_STATUS,
M1_W000_In, 1,
0x0008,
OK, Fault,
{SR05ID01CCG05:,
PRESS_STATUS,
M1_W000_In,
0,
0x0010, OK,
Fault, NO_ALARM, MAJOR, "I/O Intr"}
{SR05ID01CCG05:,
PRESS_LATCH_STATUS,
M1_W000_In, 1,
0x0010,
OK, Fault,
Let me know if you have questions or problems:
-----Original Message-----
Sent: Tuesday, January 20, 2009 12:15 PM
To: Mark Rivers
Subject: RE: Schneider Electric - BMXP342020 - CPU340-20
Hi Mark,
the goal to me is monitoring few Inputs/Outputs of those
PLC,
therefore, I'm looking to a driver/device support.
Have you got someone EPICS ioc application example to me?
I'm reading your documentation but I've found only the
Koyo
documentation, not the PLC Schneider.
Thank you very much to your support.
Mauro.
On Jan 20, 2009 06:33 PM, Mark Rivers
<[email protected]> wrote:
> Hi Mauro,
> I'm not sure exactly what you are looking for, but I
have used my
> EPICS
> Modbus driver and standard asyn device support with
these Schneider
> Modicon PLCs:
> http://cars.uchicago.edu/software/epics/modbus
> Mark
> From: [email protected]
> [mailto:[email protected]] On Behalf Of
Mauro Giacchini
> Sent: Tuesday, January 20, 2009 10:55 AM
> To: [email protected]
> Subject: PLC: Schneider Electric - BMXP342020 -
CPU340-20
> Dear all,
> Has anyone a device driver for the PLC Schneider
> CPU340-20 ?
> Thanks,
> Mauro.
> Mauro Giacchini
> Istituto Nazionale di Fisica Nucleare - Laboratori
Nazionali di
> Legnaro
> V.le dell'Universita', 2
> 35020 LEGNARO (PD) - ITALY
> Tel. +39.049.8068558
> Fax. +39.049.641925
> Skype yakman000
> EPICS _at_ LNL: http://www.lnl.infn.it/~epics/
Mauro Giacchini
Nazionali di Legnaro
V.le dell’Universita', 2
35020 LEGNARO (PD) – ITALY
Fax. +39.049.641925
EPICS _at_ LNL http://www.lnl.infn.it/~epics/
This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
