1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Vdct and autosave's info field
To: [email protected]
Cc: "Alarcon, Arturo" <[email protected]>
Date: Tue, 20 Jan 2009 14:05:03 -0500
I have been using comments like this for some time:
# @req $(S)_$(SS):Gate$(N)_$(DI):SubRevDlySet
# @arReq $(S)_$(SS):Gate$(N)_$(DI):SubRevDlySet 3600 Monitor
record(longout, "$(S)_$(SS):Gate$(N)_$(DI):SubRevDlySet") {
  field(DESC, "Sub-Revolution Delay").....
These are super easy to pull out of the expanded db file with sed. VDCT
preserves comments with the records. With a supporting make target in
the RULES file it becomes reasonably transparent.    Not elegant but
functional.
I don't maintain most of the IOCs where this PV lives so I have to do as
much as I can to help the IOC engineers if I want the timing PVs
restored.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Andrew Johnson
Sent: Tuesday, January 13, 2009 11:20 AM
Cc: Alarcon, Arturo
Subject: Re: Vdct and autosave's info field
On Tuesday 13 January 2009 09:01:03 Tim Mooney wrote:
> Autosave (v 4.3 and later) does already permit info nodes to specify
the
> fields that are to be autosaved.  However, I have not found a way to
> make vdct leave these fields in a database.
This doesn't solve the issue with vdct remembering info data (the
ability to
do so will have to be coded into vdct; if someone needs this and is
willing
to pay for it, I'm sure CosyLab will be happy to oblige), but you can at
least put the info data into a separate file.db that just contains
entries
like these:
record(type,name) {
  info(key,value)
It wouldn't be hard to write a tool to pull just these items out of an
existing .db file into a separate file; ask me if it would help and I'll
see
what I can do.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
Vdct and autosave's info field Alarcon, Arturo
Re: Vdct and autosave's info field Tim Mooney
Re: Vdct and autosave's info field Andrew Johnson
Prev: RE: Schneider Electric - BMXP342020 - CPU340-20 Mark Rivers
Next: RE: CA.DLL for Windows ? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Vdct and autosave's info field Andrew Johnson
Next: RE: Vdct and autosave's info field Alarcon, Arturo
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
