1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: sequencer cross talk!
To: "Emmanuel Mayssat" <[email protected]>, "epics" <[email protected]>
Date: Wed, 14 Jan 2009 20:02:46 -0600
If you are running 2 instances of the sequencer you need to build them with the recursive option, +r.  If you don't then it uses static variables and the 2 sequencers will interfere.
From: [email protected] on behalf of Emmanuel Mayssat
Sent: Wed 1/14/2009 7:07 PM
To: epics
Subject: sequencer cross talk!
I have 2 identical pieces of equipment (modulators).
On one computer, I start 2 IOCs, one for each modulator.
Each IOC consists of a stream/asyn driver and a sequencer.
In that configuration, it works well.
Now instead of running 2 IOCs, I decide to run only one with both
instances. ( 2 drivers and 2 sequencers)
To my surprise, with this configuration the sequencers interfere with
the PVs of the other modulator. (Note that the PVs are almost the same,
they are just prefixed differently)
Clearly in the merged IOC, the control software/sequencer doesn't work
correctly.
Has anybody already seen something like this?
Any clue?
Emmanuel
sequencer cross talk! Emmanuel Mayssat
Prev: sequencer cross talk! Emmanuel Mayssat
Next: virtual linac with libstdc++.so.6 Pierrick Hanlet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
