1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: stop all motors
To: Tim Mooney <[email protected]>
Cc: [email protected]
Date: Tue, 13 Jan 2009 14:40:38 -0500
Tim Mooney wrote:
Kate,
What version of the transform record crashed, and what version
of EPICS was it built against??  (Note that the transform record
has the field VERS.)
transformRecord.c : VERSION 5.7
against the EPICS R3.14.8.2.
Of course,  this is your choice.  It was just my courtesy
to  feedback to you that "dfanout" works well for this
application.
Kate
Kate Feng wrote:
If the "all_com_32.db" is loaded in the database, it triggered system
crash  while we were running one of our RTEMS applications.
I traced down that the bugs were caused by the "transform" record
(e.g. transformRecord.c) for the motor "allstop" function.  However,
a generic record "dfanout" can replace it to function correctly.
The attached all_com_32.db is what I used to solve the problem.
It seems to work so far.
Kate
#Kate Feng 12/30/2008:Use "dfanout" instead of "transform" for motor "allstop"
grecord(bo,"$(P)allstop") {
   field(DOL,"1")
   field(OUT,"$(P)allstop1.VAL  PP MS")
grecord(bo,"$(P)gateOpen") {
   field(ZNAM,"Closed")
   field(ONAM,"Open")
grecord(calc,"$(P)alldoneBlinker") {
   field(SCAN,".5 second")
   field(CALC,"B?0:!A")
   field(INPA,"$(P)alldoneBlinker.VAL  NPP NMS")
   field(INPB,"$(P)alldone.VAL  NPP NMS")
grecord(dfanout,"$(P)allstop5") {
   field(DESC,"allstop distribution")
   field(OMSL,"closed_loop")
   field(DOL,"1")
   field(OUTA,"$(P)m25.STOP  CA MS")
   field(OUTB,"$(P)m26.STOP  CA MS")
   field(OUTC,"$(P)m27.STOP  CA MS")
   field(OUTD,"$(P)m28.STOP  CA MS")
   field(OUTE,"$(P)m29.STOP  CA MS")
   field(OUTF,"$(P)m30.STOP  CA MS")
   field(OUTG,"$(P)m31.STOP  CA MS")
   field(OUTH,"$(P)m32.STOP  CA MS")
grecord(dfanout,"$(P)allstop4") {
   field(DOL,"1")
   field(OUTA,"$(P)m17.STOP  CA MS")
   field(OUTB,"$(P)m18.STOP  CA MS")
   field(OUTC,"$(P)m19.STOP  CA MS")
   field(OUTD,"$(P)m20.STOP  CA MS")
   field(OUTE,"$(P)m21.STOP  CA MS")
   field(OUTF,"$(P)m22.STOP  CA MS")
   field(OUTG,"$(P)m23.STOP  CA MS")
   field(OUTH,"$(P)m24.STOP  CA MS")
grecord(dfanout,"$(P)allstop3") {
   field(DOL,"1")
   field(OUTA,"$(P)m9.STOP  CA MS")
   field(OUTB,"$(P)m10.STOP  CA MS")
   field(OUTC,"$(P)m11.STOP  CA MS")
   field(OUTD,"$(P)m12.STOP  CA MS")
   field(OUTE,"$(P)m13.STOP  CA MS")
   field(OUTF,"$(P)m14.STOP  CA MS")
   field(OUTG,"$(P)m15.STOP  CA MS")
   field(OUTH,"$(P)m16.STOP  CA MS")
grecord(dfanout,"$(P)allstop2") {
   field(DOL,"1")
   field(OUTA,"$(P)m1.STOP  CA MS")
   field(OUTB,"$(P)m2.STOP  CA MS")
   field(OUTC,"$(P)m3.STOP  CA MS")
   field(OUTD,"$(P)m4.STOP  CA MS")
   field(OUTE,"$(P)m5.STOP  CA MS")
   field(OUTF,"$(P)m6.STOP  CA MS")
   field(OUTG,"$(P)m7.STOP  CA MS")
   field(OUTH,"$(P)m8.STOP  CA MS")
grecord(dfanout,"$(P)allstop1") {
   field(DOL,"1")
   field(OUTA,"$(P)AbortScans.PROC  PP MS")
   field(OUTB,"$(P)allstop2.VAL  PP MS")
   field(OUTC,"$(P)allstop3.VAL  PP MS")
   field(OUTD,"$(P)allstop4.VAL  PP MS")
   field(OUTE,"$(P)allstop5.VAL  PP MS")
grecord(swait,"$(P)alldone") {
   field(DESC,"All motors done moving")
   field(SCAN,"I/O Intr")
   field(PINI,"YES")
   field(INAN,"$(P)alldone_1.VAL")
   field(INBN,"$(P)alldone_2.VAL")
   field(INCN,"$(P)alldone_3.VAL")
   field(INDN,"$(P)alldone_4.VAL")
   field(ININ,"$(P)gateOpen.VAL")
   field(CALC,"A&&B&&C&&D&&!I")
   field(DOLD,"1")
grecord(swait,"$(P)alldone_2") {
   field(DESC,"8 motors done moving")
   field(PINI,"YES")
   field(INAN,"$(P)m9.DMOV")
   field(INBN,"$(P)m10.DMOV")
   field(INCN,"$(P)m11.DMOV")
   field(INDN,"$(P)m12.DMOV")
   field(INEN,"$(P)m13.DMOV")
   field(INFN,"$(P)m14.DMOV")
   field(INGN,"$(P)m15.DMOV")
   field(INHN,"$(P)m16.DMOV")
   field(CALC,"(a&b&c&d&e&f&g&h)=1")
   field(OOPT,"Transition To Non-zero")
   field(DOLD,"1")
grecord(swait,"$(P)alldone_1") {
   field(PINI,"YES")
   field(INAN,"$(P)m1.DMOV")
   field(INBN,"$(P)m2.DMOV")
   field(INCN,"$(P)m3.DMOV")
   field(INDN,"$(P)m4.DMOV")
   field(INEN,"$(P)m5.DMOV")
   field(INFN,"$(P)m6.DMOV")
   field(INGN,"$(P)m7.DMOV")
   field(INHN,"$(P)m8.DMOV")
   field(DOLD,"1")
grecord(swait,"$(P)alldone_3") {
   field(PINI,"YES")
   field(INAN,"$(P)m17.DMOV")
   field(INBN,"$(P)m18.DMOV")
   field(INCN,"$(P)m19.DMOV")
   field(INDN,"$(P)m20.DMOV")
   field(INEN,"$(P)m21.DMOV")
   field(INFN,"$(P)m22.DMOV")
   field(INGN,"$(P)m23.DMOV")
   field(INHN,"$(P)m24.DMOV")
   field(DOLD,"1")
grecord(swait,"$(P)alldone_4") {
   field(PINI,"YES")
   field(INAN,"$(P)m25.DMOV")
   field(INBN,"$(P)m26.DMOV")
   field(INCN,"$(P)m27.DMOV")
   field(INDN,"$(P)m28.DMOV")
   field(INEN,"$(P)m29.DMOV")
   field(INFN,"$(P)m30.DMOV")
   field(INGN,"$(P)m31.DMOV")
   field(INHN,"$(P)m32.DMOV")
   field(DOLD,"1")
grecord(swait,"$(P)alldoneBlink") {
   field(INAN,"$(P)alldone")
   field(INBN,"$(P)alldoneBlinker")
   field(CALC,"a?0:b")
stop all motors Kate Feng
Re: stop all motors Tim Mooney
Prev: RE: stop all motors Rarback, Harvey
Next: RE: EPICS asyn error message Richard Pastrick
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: stop all motors Tim Mooney
Next: Looking for Wilkinson-type ADC Liyu, Andrei V
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
